I have a setup with a base-os gw version 4.1.1 using concentratord and MQTT forwarder connected to a chirpstack 4.6.0 docker instance.
The MQTT forwarder on the gateway is configured like that:
# For a complete configuration example and documentation, please refer to:
# https://www.chirpstack.io/chirpstack-mqtt-forwarder/configuration.html
[logging]
level="info"
log_to_syslog=true
[mqtt]
topic_prefix="eu868"
#topic_prefix=""
#json=true
server="tcp://X.X.X.X:1883"
username=""
password=""
ca_cert=""
tls_cert=""
tls_key=""
[backend]
enabled="concentratord"
[backend.concentratord]
event_url="ipc:///tmp/concentratord_event"
command_url="ipc:///tmp/concentratord_command"
The chirpstack toml configuration on the server side is like that:
# Logging.
[logging]
# Log level.
level="info"
# PostgreSQL configuration.
[postgresql]
# PostgreSQL DSN.
# SSL mode options:
# * disable - no SSL
dsn="postgres://chirpstack:chirpstack@$POSTGRESQL_HOST/chirpstack?sslmode=disable"
# Max open connections.
# PostgreSQL connection pool.
max_open_connections=10
# Min idle connections.
min_idle_connections=0
# Redis configuration.
[redis]
servers=[
"redis://$REDIS_HOST/",
# TLS enabled.
tls_enabled=false
# Redis Cluster.
# instance.
cluster=false
[network]
net_id="000000"
# Enabled regions.
enabled_regions=[
"eu868",
[api]
bind="0.0.0.0:8080"
# Secret.
# openssl rand -base64 32
secret="you-must-replace-this"
[integration]
enabled=["mqtt"]
[integration.mqtt]
server="tcp://$MQTT_BROKER_HOST:1883/"
#json=true
The custom codec is programmed like that:
function Decode2(fPort, bytes) {
var tempObj = new Object();
tempObj.byte1 = bytes[0];
tempObj.byte2 = bytes[1];
tempObj.byte3 = bytes[2];
tempObj.byte4 = bytes[3];
tempObj.byte5 = bytes[4];
tempObj.byte6 = bytes[5];
tempObj.byte7 = bytes[6];
tempObj.byte8 = bytes[7];
tempObj.byte9 = bytes[8];
tempObj.byte10 = bytes[9];
tempObj.byte11 = bytes[10];
tempObj.byte12 = bytes[11];
tempObj.byte13 = bytes[12];
return tempObj;
function decodeUplink(input) {
// Wrapper function for ChirpStack v4
//var myData = Decode(input.fPort, input.bytes, input.variables);
var myData = Decode2(input.fPort, input.bytes);
myData.node_name = input.variables.node_name;
return {
data: myData
Now, what I see is extremely strange.
The gw is properly receiving the payload from the IoT device and sends it to the server.
In the server, if I monitor the device, I am seeing very strange things.
When monitoring the frames, I am seeing things like that:
Multiple things to note here:
- why is the data displayed in JSON and note base64 ?
- I have (manually…) checked the data and they correspond to the right value, the value that the IoT device sent
When I am montiring the events, I am seeing things like that:
So, basically, after testing lots of things on the codec I came to the conclusion that I can’t really access the data in the received packets.
Does anyone know what I’m doing wrong here ?
Thanks in advance
