I’m trying to port Yocto based Gateway OS to other BSP like beaglebone black by using https://github.com/chirpstack/chirpstack-gateway-os V4 .
While building the chirpstack-gateway-os-base i’m getting below errors.
Which specify i can not use this with a stable version of rust compiler.
For that reason i’ve modified ./openembedded-core/meta/recipe-devtools/rust.inc line 104
config.set(“rust”, “channel”, e(“stable”)) to config.set(“rust”, “channel”, e(“nightly”))
but still i’m not able to build the image successfully.
