Unable to communication between
I’m using RAK2287 SPI without GPS as HAT on Raspberry pi 4.
I’ve downloaded chirpstack-gateway-os SD Factory Image Full for Raspberry Pi 4B from the chirpstack website
Connected using WIFI AP and processed below steps.
  1. Change password → Save & Apply
  2. Global Configuration [ SX1302 ] → Save & Apply
  3. SX1302/SX1303 → Shild Model [ RAK 2287] → Channel Plan [ IN865 ] → GNSS [ UNTICK ] → USB [ UNTICK ] → Save & Apply
  4. Network → Wireless → Scan → Join Network [ WIFI name ] → Replace Wireless Configuration [ TICK ] → WPA Passphrase [ Password ] → Create / Assign Firewall-zone [ lan ] → Submit → Save → Save & Apply.
Found IP-Adress using router and loggen in using web interface.
  1. Application → Chirpstack.
  2. Tenants → Delete Tenants.
  3. Add Tenant → Name [ TENANT1 ] → Tenant can have gateways [ TICK ] → Gateways are private (uplink) [ UNTICK ] → Gateways are private (downlink) [ UNTICK ] → Max gateways [ 0 ] → Max device count [ 0 ] → Submit.
  4. Application → Add Application → Name [ APP ] → Submit.
  5. Device Profile → Add Device Profile → Name [ DEVICE-PROFILE ] → Region [ IN865 ] → Region configuration [ IN865 ] → MAC version [ LoraWan 1.0.3 ] → Regional Parameter revision [ A ] → ADR algorithm [ Default ADR algorithm (LoRa only) ] → Flush queue on activate [ TICK ] → Expected uplink interval [ 3600 ] → Device-status request frequency [ 1 ] → Submit.
  6. Add Device → Name [ DEVICE1 ] → Device EUI [ 36:30:38:32:69:30:72:10 ] → Device Profile [ DEVICE-PROFILE ] → Application Key [ 2B,7E,15,16,28,AE,D2,A6,AB,F7,15,88,09,CF,4F,3C ] → Submit.
  7. Gateway → Add Gateway → Name [ GATEWAY1 ] → Gateway ID [ 0016C001F1075349 ] → Submit.
I did updated log levels to TRACE in chirpstack-mqtt-forwarder,chirpstack-concentratord,chirpstack
Here is the output that indicates after receiving config command concentratod keeps restarting
user.notice firewall: Reloading firewall due to ifup of wwan (phy0-sta0)
daemon.notice mosquitto[1460]: 1696586902: New connection from 127.0.0.1:60386 on port 1883.
daemon.notice mosquitto[1460]: 1696586902: New client connected from 127.0.0.1:60386 as 5886e1ae0b06f067 (p2, c0, k30).
daemon.notice mosquitto[1460]: 1696586902: New connection from 127.0.0.1:60396 on port 1883.
daemon.info dnsmasq[1]: read /etc/hosts - 12 names
daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 0 names
daemon.notice mosquitto[1460]: 1696586903: New connection from 192.168.0.113:38858 on port 1883.
daemon.notice mosquitto[1460]: 1696586903: New client connected from 192.168.0.113:38858 as mqtt-explorer-f7c2c85e (p2, c1, k60).
user.debug chirpstack-concentratord-sx1302[2110]: Getting gateway EUI
user.info chirpstack-concentratord-sx1302[2110]: Gateway ID retrieved, gateway_id: "0016c001f1075349"
user.info chirpstack-concentratord-sx1302[2110]: Initializing JIT queue, capacity: 32
user.info chirpstack-concentratord-sx1302[2110]: Creating socket for publishing events, bind: ipc:///tmp/concentratord_event
user.info chirpstack-concentratord-sx1302[2110]: Creating socket for receiving commands, bind: ipc:///tmp/concentratord_command
user.debug chirpstack-concentratord-sx1302[2110]: Starting uplink handle loop
user.debug chirpstack-concentratord-sx1302[2110]: Starting JIT queue loop
user.debug chirpstack-concentratord-sx1302[2110]: Starting command handler loop
user.debug chirpstack-concentratord-sx1302[2110]: Starting stats loop, stats_interval: 30s
daemon.notice mosquitto[1460]: 1696586904: New client connected from 127.0.0.1:60396 as c825d02561e69a9b (p2, c0, k30).
daemon.err uwsgi[1253]: *** has_emperor mode detected (fd: 7) ***
daemon.err uwsgi[1253]: [uWSGI] getting INI configuration from /etc/uwsgi/vassals/luci-webui.ini
daemon.err uwsgi[1253]: - [emperor] vassal /etc/uwsgi/vassals/luci-webui.ini has been spawned
daemon.info uwsgi-luci: spawned uWSGI master process (pid: 2676)
daemon.err uwsgi[1253]: - [emperor] vassal /etc/uwsgi/vassals/luci-webui.ini is ready to accept requests
user.debug chirpstack-concentratord-sx1302[2110]: Could not get GPS epoch, uplink_id: 685638646, error: gps_ref_valid = false
user.debug chirpstack-concentratord-sx1302[2110]: Could not get GPS time, uplink_id: 685638646, error: gps_ref_valid = false
user.info chirpstack-concentratord-sx1302[2110]: Frame received, uplink_id: 685638646, count_us: 2500174, freq: 865062500, bw: 125000, mod: LoRa, dr: SF12, ftime_received: false, ftime_ns: 0
daemon.err uwsgi[1253]: - [emperor] vassal /etc/uwsgi/vassals/luci-webui.ini is now loyal
daemon.info uwsgi-luci: [info] luci: accepted login on /admin/status/logs for root from 192.168.0.113
daemon.err uwsgi[1253]: *** has_emperor mode detected (fd: 8) ***
daemon.err uwsgi[1253]: [uWSGI] getting INI configuration from /etc/uwsgi/vassals/luci-cgi_io.ini
daemon.err uwsgi[1253]: - [emperor] vassal /etc/uwsgi/vassals/luci-cgi_io.ini has been spawned
daemon.err uwsgi[1253]: - [emperor] vassal /etc/uwsgi/vassals/luci-cgi_io.ini is ready to accept requests
daemon.err uwsgi[1253]: - [emperor] vassal /etc/uwsgi/vassals/luci-cgi_io.ini is now loyal
user.info chirpstack-mqtt-forwarder[2732]: Starting ChirpStack MQTT Forwarder (version: 4.1.1, docs: https://www.chirpstack.io/)
user.info chirpstack-mqtt-forwarder[2732]: Setting up ChirpStack Concentratord backend
user.info chirpstack-mqtt-forwarder[2732]: Connecting to Concentratord event API, event_url: ipc:///tmp/concentratord_event
user.info chirpstack-mqtt-forwarder[2732]: Connecting to Concentratord command API, command_url: ipc:///tmp/concentratord_command
user.info chirpstack-mqtt-forwarder[2732]: Reading gateway id
user.info chirpstack-mqtt-forwarder[2732]: Received gateway id, gateway_id: 0016c001f1075349
user.debug chirpstack-mqtt-forwarder[2732]: Retrieving Gateway ID from backend
user.debug chirpstack-mqtt-forwarder[2732]: Starting event loop
user.info chirpstack-mqtt-forwarder[2732]: Received Gateway ID from backend, gateway_id: 0016c001f1075349
user.debug chirpstack-mqtt-forwarder[2732]: Setting up MQTT client
user.debug chirpstack-mqtt-forwarder[2732]: Create options: CreateOptions { copts: MQTTAsync_createOptions { struct_id: [77, 81, 67, 79], struct_version: 2, sendWhileDisconnected: 0, maxBufferedMessages: 100, MQTTVersion: 5, allowDisconnectedSendAtAnyTime: 0, deleteOldestMessages: 0, restoreMessages: 1, persistQoS0: 1 }, server_uri: "tcp://localhost:1883", client_id: "0016c001f1075349", persistence: File with Path, user_data: None }
user.debug chirpstack-mqtt-forwarder[2732]: Creating client with persistence: 0
user.debug chirpstack-mqtt-forwarder[2732]: AsyncClient w/ Inner 0xb5fa42e8 and Handle: 0xb621c1c0
user.info chirpstack-mqtt-forwarder[2732]: Connecting to MQTT broker, server: tcp://localhost:1883, clean_session: false, client_id: 0016c001f1075349, qos: 0
user.debug chirpstack-mqtt-forwarder[2732]: Connecting. Handle: 0xb621c1c0
user.debug chirpstack-mqtt-forwarder[2732]: Updating client MQTT version: 0
user.debug chirpstack-mqtt-forwarder[2732]: Connect options: ConnectOptions { copts: MQTTAsync_connectOptions { struct_id: [77, 81, 84, 67], struct_version: 8, keepAliveInterval: 60, cleansession: 0, maxInflight: 65535, will: 0xb5f76998, username: 0x0, password: 0x0, connectTimeout: 30, retryInterval: 0, ssl: 0x0, onSuccess: Some(0x52e700), onFailure: Some(0x52e820), context: 0xb5f762a8, serverURIcount: 0, serverURIs: 0x0, MQTTVersion: 0, automaticReconnect: 1, minRetryInterval: 1, maxRetryInterval: 30, binarypwd: MQTTAsync_connectOptions__bindgen_ty_1 { len: 0, data: 0x0 }, cleanstart: 0, connectProperties: 0x0, willProperties: 0x0, onSuccess5: None, onFailure5: None, httpHeaders: 0x0, httpProxy: 0x0, httpsProxy: 0x0 }, data: ConnectOptionsData { will: Some(WillOptions { copts: MQTTAsync_willOptions { struct_id: [77, 81, 84, 87], struct_version: 1, topicName: 0xb5f7b5b0, message: 0x0, retained: 1, qos: 0, payload: MQTTAsync_willOptions__bindgen_ty_1 { len: 18, data: 0xb5f76790 } }, data: MessageDat
daemon.notice mosquitto[1460]: 1696586972: New connection from 127.0.0.1:60406 on port 1883.
daemon.notice mosquitto[1460]: 1696586972: New client connected from 127.0.0.1:60406 as 0016c001f1075349 (p2, c0, k60).
user.debug chirpstack-mqtt-forwarder[2732]: Token success! Token: 0xb5f762a8, Response: 0xb5f4dc00
user.debug chirpstack-mqtt-forwarder[2732]: Completing Token w ID 0 and code: 0
user.debug chirpstack-mqtt-forwarder[2732]: Expecting server response for: Connect
user.debug chirpstack-mqtt-forwarder[2732]: Got response: ServerResponse { rsp: Connect(ConnectResponse { server_uri: "localhost:1883", mqtt_version: 4, session_present: false }), props: Properties { cprops: MQTTProperties { count: 0, max_count: 0, length: 0, array: 0x0 } }, reason_code: Success }
user.debug chirpstack-mqtt-forwarder[2732]: Updating client MQTT version: 4
user.debug chirpstack-mqtt-forwarder[2732]: Connected! Client 0xb5fa42e8
user.debug chirpstack-mqtt-forwarder[2732]: Invoking connected callback
user.info chirpstack-mqtt-forwarder[2732]: Starting MQTT consumer loop
user.info chirpstack-mqtt-forwarder[2732]: Connected to MQTT broker
user.info chirpstack-mqtt-forwarder[2732]: Subscribing to command topic, topic: in865/gateway/0016c001f1075349/command/+
user.debug chirpstack-mqtt-forwarder[2732]: Subscribe to '"in865/gateway/0016c001f1075349/command/+"' @ QOS 0
user.debug chirpstack-mqtt-forwarder[2732]: Token success! Token: 0xb5f761a8, Response: 0xb5f4dc00
user.debug chirpstack-mqtt-forwarder[2732]: Completing Token w ID 1 and code: 0
user.debug chirpstack-mqtt-forwarder[2732]: Expecting server response for: Subscribe
user.debug chirpstack-mqtt-forwarder[2732]: Got response: ServerResponse { rsp: Subscribe(0), props: Properties { cprops: MQTTProperties { count: 0, max_count: 0, length: 0, array: 0x0 } }, reason_code: Success }
user.info chirpstack-mqtt-forwarder[2732]: Sending conn state, topic: in865/gateway/0016c001f1075349/state/conn
user.debug chirpstack-mqtt-forwarder[2732]: Publish: Message { cmsg: MQTTAsync_message { struct_id: [77, 81, 84, 77], struct_version: 1, payloadlen: 20, payload: 0xb5f77730, qos: 0, retained: 1, dup: 0, msgid: 0, properties: MQTTProperties { count: 0, max_count: 0, length: 0, array: 0x0 } }, data: MessageData { topic: "in865/gateway/0016c001f1075349/state/conn", payload: [16, 1, 26, 16, 48, 48, 49, 54, 99, 48, 48, 49, 102, 49, 48, 55, 53, 51, 52, 57], props: Properties { cprops: MQTTProperties { count: 0, max_count: 0, length: 0, array: 0x0 } } } }
user.debug chirpstack-mqtt-forwarder[2732]: Token success! Token: 0xb5f762a8, Response: 0xb5f70b8c
user.debug chirpstack-mqtt-forwarder[2732]: Expecting server response for: None
user.debug chirpstack-mqtt-forwarder[2732]: Got response: ServerResponse { rsp: None, props: Properties { cprops: MQTTProperties { count: 0, max_count: 0, length: 0, array: 0x0 } }, reason_code: Success }
user.debug chirpstack-concentratord-sx1302[2110]: Could not get GPS epoch, uplink_id: 2104690443, error: gps_ref_valid = false
user.debug chirpstack-concentratord-sx1302[2110]: Could not get GPS time, uplink_id: 2104690443, error: gps_ref_valid = false
user.info chirpstack-concentratord-sx1302[2110]: Frame received, uplink_id: 2104690443, count_us: 11538385, freq: 865402500, bw: 125000, mod: LoRa, dr: SF12, ftime_received: false, ftime_ns: 0
user.info chirpstack-mqtt-forwarder[2732]: Received uplink frame, uplink_id: 2104690443
user.info chirpstack-mqtt-forwarder[2732]: Sending uplink event, uplink_id: 2104690443, topic: in865/gateway/0016c001f1075349/event/up
user.debug chirpstack-mqtt-forwarder[2732]: Publish: Message { cmsg: MQTTAsync_message { struct_id: [77, 81, 84, 77], struct_version: 1, payloadlen: 98, payload: 0xb5f79e80, qos: 0, retained: 0, dup: 0, msgid: 0, properties: MQTTProperties { count: 0, max_count: 0, length: 0, array: 0x0 } }, data: MessageData { topic: "in865/gateway/0016c001f1075349/event/up", payload: [10, 23, 0, 0, 0, 0, 0, 0, 0, 0, 0, 72, 109, 0, 0, 5, 246, 193, 60, 203, 224, 49, 77, 62, 138, 34, 18, 8, 132, 253, 211, 156, 3, 18, 10, 26, 8, 8, 200, 208, 7, 16, 12, 40, 1, 42, 51, 10, 16, 48, 48, 49, 54, 99, 48, 48, 49, 102, 49, 48, 55, 53, 51, 52, 57, 16, 139, 142, 204, 235, 7, 48, 238, 254, 255, 255, 255, 255, 255, 255, 255, 1, 61, 0, 0, 120, 193, 64, 1, 106, 4, 0, 176, 15, 209, 128, 1, 2], props: Properties { cprops: MQTTProperties { count: 0, max_count: 0, length: 0, array: 0x0 } } } }
user.debug chirpstack-mqtt-forwarder[2732]: Token success! Token: 0xb5f76228, Response: 0xb5f70b8c
user.debug chirpstack-mqtt-forwarder[2732]: Message sent
user.debug chirpstack-concentratord-sx1302[2110]: Could not get GPS epoch, uplink_id: 1781288615, error: gps_ref_valid = false
user.debug chirpstack-concentratord-sx1302[2110]: Could not get GPS time, uplink_id: 1781288615, error: gps_ref_valid = false
user.info chirpstack-concentratord-sx1302[2110]: Frame received, uplink_id: 1781288615, count_us: 22575827, freq: 865985000, bw: 125000, mod: LoRa, dr: SF12, ftime_received: false, ftime_ns: 0
user.info chirpstack-mqtt-forwarder[2732]: Received uplink frame, uplink_id: 1781288615
user.info chirpstack-mqtt-forwarder[2732]: Sending uplink event, uplink_id: 1781288615, topic: in865/gateway/0016c001f1075349/event/up
user.debug chirpstack-mqtt-forwarder[2732]: Publish: Message { cmsg: MQTTAsync_message { struct_id: [77, 81, 84, 77], struct_version: 1, payloadlen: 100, payload: 0xb5f7c8b0, qos: 0, retained: 0, dup: 0, msgid: 0, properties: MQTTProperties { count: 0, max_count: 0, length: 0, array: 0x0 } }, data: MessageData { topic: "in865/gateway/0016c001f1075349/event/up", payload: [10, 23, 0, 0, 0, 0, 0, 0, 0, 0, 0, 72, 109, 0, 0, 5, 246, 193, 60, 140, 238, 34, 230, 144, 255, 34, 18, 8, 232, 195, 247, 156, 3, 18, 10, 26, 8, 8, 200, 208, 7, 16, 12, 40, 1, 42, 53, 10, 16, 48, 48, 49, 54, 99, 48, 48, 49, 102, 49, 48, 55, 53, 51, 52, 57, 16, 167, 157, 177, 209, 6, 48, 158, 255, 255, 255, 255, 255, 255, 255, 255, 1, 61, 0, 0, 192, 63, 64, 2, 72, 1, 106, 4, 1, 88, 122, 211, 128, 1, 2], props: Properties { cprops: MQTTProperties { count: 0, max_count: 0, length: 0, array: 0x0 } } } }
user.info chirpstack-concentratord-sx1302[2110]: Publishing stats event, rx_received: 3, rx_received_ok: 3, tx_received: 0, tx_emitted: 0
user.info chirpstack-mqtt-forwarder[2732]: Received gateway stats
user.info chirpstack-mqtt-forwarder[2732]: Sending gateway stats event, topic: in865/gateway/0016c001f1075349/event/stats
user.debug chirpstack-mqtt-forwarder[2732]: Publish: Message { cmsg: MQTTAsync_message { struct_id: [77, 81, 84, 77], struct_version: 1, payloadlen: 184, payload: 0xb6ce7a70, qos: 0, retained: 0, dup: 0, msgid: 0, properties: MQTTProperties { count: 0, max_count: 0, length: 0, array: 0x0 } }, data: MessageData { topic: "in865/gateway/0016c001f1075349/event/stats", payload: [18, 12, 8, 245, 185, 255, 168, 6, 16, 154, 191, 206, 222, 2, 40, 3, 48, 3, 82, 30, 10, 21, 99, 111, 110, 99, 101, 110, 116, 114, 97, 116, 111, 114, 100, 95, 118, 101, 114, 115, 105, 111, 110, 18, 5, 52, 46, 51, 46, 48, 82, 16, 10, 14, 99, 111, 110, 102, 105, 103, 95, 118, 101, 114, 115, 105, 111, 110, 82, 17, 10, 5, 109, 111, 100, 101, 108, 18, 8, 114, 97, 107, 95, 50, 50, 56, 55, 82, 30, 10, 11, 104, 97, 108, 95, 118, 101, 114, 115, 105, 111, 110, 18, 15, 86, 101, 114, 115, 105, 111, 110, 58, 32, 50, 46, 49, 46, 48, 59, 106, 8, 8, 132, 253, 211, 156, 3, 16, 1, 106, 8, 8, 232, 195, 247, 156, 3, 16, 1, 106, 8, 8, 228, 156, 191, 15
user.debug chirpstack-mqtt-forwarder[2732]: Token success! Token: 0xb64260b8, Response: 0xb5f70b8c
user.debug chirpstack-mqtt-forwarder[2732]: Message arrived. Client: 0xb5fa42e8, topic: 0xb5f73350 len 45 cmsg: 0xb5f73390: MQTTAsync_message { struct_id: [77, 81, 84, 77], struct_version: 1, payloadlen: 112, payload: 0xb5f761a0, qos: 0, retained: 0, dup: 0, msgid: 0, properties: MQTTProperties { count: 0, max_count: 0, length: 0, array: 0x0 } }
user.debug chirpstack-mqtt-forwarder[2732]: Invoking message callback
user.info chirpstack-mqtt-forwarder[2732]: Received message, topic: in865/gateway/0016c001f1075349/command/config, qos: 0
user.info chirpstack-mqtt-forwarder[2732]: Received configuration command, version: b150e28b5f522992, topic: in865/gateway/0016c001f1075349/command/config
user.info chirpstack-mqtt-forwarder[2732]: Sending configuration command, version: b150e28b5f522992
user.debug chirpstack-concentratord-sx1302[2110]: Received stop signal, signal: Configuration
user.debug chirpstack-concentratord-sx1302[2110]: Stats loop ended
user.debug chirpstack-concentratord-sx1302[2110]: JIT loop ended
user.debug chirpstack-concentratord-sx1302[2110]: Uplink loop ended
user.debug chirpstack-concentratord-sx1302[2110]: Command loop ended
user.info chirpstack-concentratord-sx1302[2110]: Stopping the concentrator
user.info chirpstack-concentratord-sx1302[2110]: Updating concentrator configuration
user.info chirpstack-concentratord-sx1302[2110]: Starting Concentratord SX1302 (version: 4.3.0, docs: https://www.chirpstack.io/docs/chirpstack-concentratord/)
user.info chirpstack-concentratord-sx1302[2110]: Triggering sx1302 reset
user.info chirpstack-concentratord-sx1302[2110]: Setting i2c device path, path: /dev/i2c-1
user.info chirpstack-concentratord-sx1302[2110]: Setting board configuration, lorawan_public: true, clock_source: 0
user.info chirpstack-concentratord-sx1302[2110]: Setting up fine timestamp, enable: false
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 12, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 4
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 13, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 5
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 14, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 6
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 15, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 7
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 16, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 8
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 17, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 9
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 18, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 10
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 19, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 11
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 20, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 12
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 21, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 13
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 22, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 14
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 23, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 16
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 24, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 17
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 25, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 18
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 26, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 19
user.debug chirpstack-concentratord-sx1302[2110]: Configuration TX gain for radio, radio: 0, rf_power: 27, dig_gain: 0, pa_gain: 1, dac_gain: 0, mix_gain: 5, offset_i: 0, offset_q: 0, pwr_idx: 22
user.info chirpstack-concentratord-sx1302[2110]: Setting up concentrator channels
user.info chirpstack-concentratord-sx1302[2110]: Configuring radio, radio: 0, enabled: true, center_freq: 865462500, type: SX1250
user.info chirpstack-concentratord-sx1302[2110]: Configuring radio, radio: 1, enabled: true, center_freq: 866385000, type: SX1250
user.info chirpstack-concentratord-sx1302[2110]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 865062500, rf_chain: 0, if_freq: -400000
user.info chirpstack-concentratord-sx1302[2110]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 865402500, rf_chain: 0, if_freq: -60000
user.info chirpstack-concentratord-sx1302[2110]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 865985000, rf_chain: 1, if_freq: -400000
user.info chirpstack-concentratord-sx1302[2110]: Configuring multi-SF LoRa channel, channel: 3, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
user.info chirpstack-concentratord-sx1302[2110]: Configuring multi-SF LoRa channel, channel: 4, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
user.info chirpstack-concentratord-sx1302[2110]: Configuring multi-SF LoRa channel, channel: 5, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
user.info chirpstack-concentratord-sx1302[2110]: Configuring multi-SF LoRa channel, channel: 6, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
user.info chirpstack-concentratord-sx1302[2110]: Configuring multi-SF LoRa channel, channel: 7, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
user.info chirpstack-concentratord-sx1302[2110]: Configuring Std LoRa channel, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
user.info chirpstack-concentratord-sx1302[2110]: Configuring FSK channel, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
user.info chirpstack-concentratord-sx1302[2110]: Starting the concentrator
user.info chirpstack-concentratord-sx1302[2844]: Configuring reset pin, dev: /dev/gpiochip0, pin: 17
user.info chirpstack-concentratord-sx1302[2844]: Starting Concentratord SX1302 (version: 4.3.0, docs: https://www.chirpstack.io/docs/chirpstack-concentratord/)
user.info chirpstack-concentratord-sx1302[2844]: Triggering sx1302 reset
user.info chirpstack-concentratord-sx1302[2844]: Setting i2c device path, path: /dev/i2c-1
user.info chirpstack-concentratord-sx1302[2844]: Setting board configuration, lorawan_public: true, clock_source: 0
user.info chirpstack-concentratord-sx1302[2844]: Setting up fine timestamp, enable: false
Have you tried the reference software from Semtech (i.e. BasicStation/UDP packet forwarder for SX1302) or even RAK’s RPi images for the RAK2287? If it doesn’t work, maybe you need to get support from the manufacturer.
If it actually works, why not try continuing with that?
I would actually encourage the use of a standard packet forwarder (either the UDP packet forwarder or BasicStation), not because I encourage working around the issue, but because a packet forwarder like these would not limit you to only Chirpstack.
In your log I see exactly one received config command:
After this, the Concentratord indeed restart once and I see the following log exactly once:
So I do not understand keeps restarting because looking at your logs, this is not the case. It receives a config update once and it restart once. All looks fine to me…
Restarting logs are intentionally removed as they are repeating the same text starting from the line.
If you require i can publish the log.
Yes, a bit more log context would be helpful :slight_smile:
