Hello
Fresh install
My gateway is set up with lorafwd, declared on Debian chirpstack server
This server is running chirpstack-network-server and chirpstack-gateway-bridge an chirpstack-application-server
When i Check chirpstack-gateway-bridge logs : Everything seems ok :
oct. 19 18:19:34 chirpstack chirpstack-gateway-bridge[1984]: time=“2022-10-19T18:19:34.504072143+02:00” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 topic=gateway/acc10e23085876db/event/stats
oct. 19 18:20:04 chirpstack chirpstack-gateway-bridge[1984]: time=“2022-10-19T18:20:04.50785509+02:00” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 topic=gateway/acc10e23085876db/event/stats
oct. 19 18:20:34 chirpstack chirpstack-gateway-bridge[1984]: time=“2022-10-19T18:20:34.510395507+02:00” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 topic=gateway/acc10e23085876db/event/stats
oct. 19 18:21:04 chirpstack chirpstack-gateway-bridge[1984]: time=“2022-10-19T18:21:04.513855378+02:00” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 topic=gateway/acc10e23085876db/event/stats
But When I check chirpstack-network-server logs, the gateway_id disappears : so no data
oct. 19 18:20:34 chirpstack chirpstack-network-server[1892]: time=“2022-10-19T18:20:34.512399064+02:00” level=error msg=“gateway: handle gateway stats error” ctx_id=00000000-0000-0000-0000-000000000000 error=“update gateway state error: object does not exist”
oct. 19 18:21:04 chirpstack chirpstack-network-server[1892]: time=“2022-10-19T18:21:04.514654465+02:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=0000000000000000 stats_id=00000000-0000-0000-0000-000000000000
oct. 19 18:21:04 chirpstack chirpstack-network-server[1892]: time=“2022-10-19T18:21:04.515452371+02:00” level=error msg=“gateway: handle gateway stats error” ctx_id=00000000-0000-0000-0000-000000000000 error=“update gateway state error: object does not exist”
oct. 19 18:21:34 chirpstack chirpstack-network-server[1892]: time=“2022-10-19T18:21:34.517353239+02:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=0000000000000000 stats_id=00000000-0000-0000-0000-000000000000
oct. 19 18:21:34 chirpstack chirpstack-network-server[1892]: time=“2022-10-19T18:21:34.518322986+02:00” level=error msg=“gateway: handle gateway stats error” ctx_id=00000000-0000-0000-0000-000000000000 error=“update gateway state error: object does not exist”
oct. 19 18:22:04 chirpstack chirpstack-network-server[1892]: time=“2022-10-19T18:22:04.52049139+02:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=0000000000000000 stats_id=00000000-0000-0000-0000-000000000000
oct. 19 18:22:04 chirpstack chirpstack-network-server[1892]: time=“2022-10-19T18:22:04.521241529+02:00” level=error msg=“gateway: handle gateway stats error” ctx_id=00000000-0000-0000-0000-000000000000 error=“update gateway state error: object does not exist”
