Unable to locate package chipstack-gateway-bridge [Key EXPIRED]
While installing chirpstack-gateway-bridge component, I’m getting the following error. Could someone please help me here.
pi@raspberrypi:~ $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 1CE2AFD36DBCCA00
Executing: /tmp/apt-key-gpghome.GxgLpDwYiv/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 1CE2AFD36DBCCA00
gpg: key 1CE2AFD36DBCCA00: “Orne Brocaar info@brocaar.com” not changed
gpg: Total number processed: 1
gpg: unchanged: 1
pi@raspberrypi:~ $ sudo echo “deb https://artifacts.chirpstack.io/packages/3.x/deb stable main” | sudo tee /etc/apt/sources.list.d/chirpstack.list
pi@raspberrypi:~ $ sudo apt-get update
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 http://download.opensuse.org/repositories/home:/strycore/Raspbian_10 InRelease
Get:4 https://artifacts.chirpstack.io/packages/3.x/deb stable InRelease [14.0 kB]
Err:4 https://artifacts.chirpstack.io/packages/3.x/deb stable InRelease
The following signatures were invalid: EXPKEYSIG CFF064C9D12ECB34 Orne Brocaar info@brocaar.com
Reading package lists… Done
W: GPG error: https://artifacts.chirpstack.io/packages/3.x/deb stable InRelease: The following signatures were invalid: EXPKEYSIG CFF064C9D12ECB34 Orne Brocaar info@brocaar.com
E: The repository ‘https://artifacts.chirpstack.io/packages/3.x/deb stable InRelease’ is not signed.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
pi@raspberrypi:~ $ sudo apt-get install chipstack-gateway-bridge
Building dependency tree
Reading state information… Done
E: Unable to locate package chipstack-gateway-bridge
You has typo in package name, ‘r’ is missed. chirpstack-gateway-bridge
This has been fixed, the keyserver in GPG Keychain was not set to keyserver.ubuntu.com :man_facepalming:
It might actually be a good idea to host the public-key on https://artifacts.chirpstack.io so people can pull it directly from there instead of using keyserver.ubuntu.com. Some people have had issues with that in the past so this solves two issues.
You should re-run the following command to fetch the update:
Please let me know if that solves your issue (it did for me).
Thank you very much for the update. Will check it.
It worked!!
Thank you
Great, sorry for the inconvenience (also to others who experienced this issue) and thanks for reporting!
I’m having the same issue again, even tried deleting the keys and reloading them. Still get the error
“Err:5 https://artifacts.chirpstack.io/packages/3.x/deb stable Release
Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 188.166.134.65 443]”
Solved: This was a docker installation: had to run
sudo apt install ca-certificates
Then everything worked.
Hi, I’m having the same problem. I can’t find the key in keyserver.ubuntu.com, and when i run this command the rasp returns “gpg: keyserver receive failed: Connection timed out”
check your internet connection, dns, firewall
I’m searching for this problems. Is the key working fine?
sure.
but in your case, your system can’t connect to the keyserver.
it worked. thank you very much <3
Hi everyone !
First here, nice to meet you. I have the similar issue with " E: Unable to locate package chirpstack-gateway-bridge"
Also. E: Failed to fetch https://artifacts.chirpstack.io/packages/3.x/deb/dists/3/stable/binary-amd64/Packages Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 188.166.134.65 443]
Can anybody help? Thanks a lot in advance
Hi.
Can i see all of your commands to solve this problem?
Good morning you all!
I am experiencing same issues here. After looking for the GPG key, I assume it is expired since yesterday:
https://keyserver.ubuntu.com/pks/lookup?search=info%40brocaar.com&fingerprint=on&op=index
Happy New Year!
Hi.
Can you please show me all of the commands i have to run to solve this problem? Here is my commands:
  1. sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 1CE2AFD36DBCCA00
  2. sudo echo “deb https://artifacts.chirpstack.io/packages/3.x/deb stable main” | sudo tee /etc/apt/sources.list.d/chirpstack.list
  3. sudo apt update
    But it doesn’t work.
GPG key is currently expired, hp14. Let’s wait for it to be renewed to solve this issue!
You mean the GPG key in this guide in ChirpStack documentation:
