Hello, I need to use different port than default 8080 for my chirpstack application server, but when I change it in my docker-compose.yml its not working at all.
docker-compose.yml:
version: "3"
services:
chirpstack:
image: chirpstack/chirpstack:4.0.0-rc.2
command: -c /etc/chirpstack
restart: unless-stopped
volumes:
- ./lorawan-devices:/opt/lorawan-devices
depends_on:
- postgres
- mosquitto
- redis
ports:
- 9090:9090 #changed from - 8080:8080
chirpstack-gateway-bridge-eu433:
image: chirpstack/chirpstack-gateway-bridge:4.0.0-rc.1
ports:
- 1700:1700/udp
volumes:
depends_on:
- mosquitto
chirpstack-rest-api:
image: chirpstack/chirpstack-rest-api:4.0.0-rc.1
command: --server chirpstack:9090 --bind 0.0.0.0:8090 --insecure #changed from command: --server chirpstack:8080 --bind 0.0.0.0:8090 --insecure
ports:
- 8090:8090
depends_on:
- chirpstack
postgres:
image: postgres:14-alpine
volumes:
environment:
- POSTGRES_PASSWORD=root
redis:
image: redis:7-alpine
volumes:
- redisdata:/data
mosquitto:
image: eclipse-mosquitto:2
ports:
- 1883:1883
volumes:
- ./configuration/mosquitto/mosquitto.conf:/mosquitto/config/mosquitto.conf
volumes:
postgresqldata:
redisdata:
/configuration/chirpstack/chirpstack.toml:
# Logging.
[logging]
# Log level.
level="info"
# PostgreSQL configuration.
[postgresql]
# PostgreSQL DSN.
# SSL mode options:
# * disable - no SSL
dsn="postgres://chirpstack:chirpstack@postgres/chirpstack?sslmode=disable"
# Max open connections.
# PostgreSQL connection pool.
max_open_connections=10
# Min idle connections.
min_idle_connections=0
# Redis configuration.
[redis]
servers=[
"redis://redis/",
# TLS enabled.
tls_enabled=false
# Redis Cluster.
# instance.
cluster=false
[network]
net_id="000000"
# Enabled regions.
enabled_regions=[
"as923",
"as923_2",
"as923_3",
"as923_4",
"au915_0",
"cn779",
"eu433",
"eu868",
"in865",
"ism2400",
"kr920",
"ru864",
"us915_0",
"us915_1",
[api]
bind="0.0.0.0:9090" # changed from bind="0.0.0.0:8080"
# Secret.
# openssl rand -base64 32
secret="you-must-replace-this"
[gateway]
client_cert_lifetime="365days"
ca_cert="configuration/certs/ca.crt"
ca_key="configuration/certs/ca.key"
[integration]
enabled=["mqtt"]
[integration.mqtt]
server="tcp://mosquitto:1883/"
json=true
[integration.mqtt.client]
/configuration/chirpstack-gateway-bridge/chirpstack-gateway-bridge.toml:
# See https://www.chirpstack.io/gateway-bridge/install/config/ for a full
# configuration example and documentation.
servers=["tcp://mosquitto:1883"]
username=""
password=""
[integration.mqtt]
event_topic_template="eu433/gateway/{{ .GatewayID }}/event/{{ .EventType }}" #changed from event_topic_template="eu868/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
state_topic_template="eu433/gateway/{{ .GatewayID }}/state/{{ .StateType }}" #changed from state_topic_template="868/gateway/{{ .GatewayID }}/state/{{ .StateType }}"
command_topic_template="eu433/gateway/{{ .GatewayID }}/command/#" #changed from command_topic_template="eu868/gateway/{{ .GatewayID }}/command/#"
Where is my problem? Did I change something I wasn’t supposed to, or am I missing something?
