Hello and good day to you…
I have multitech conduit gateway. I am trying to install gateway bridge on my gateway by login to my gateway using ssh, and then perform the command:
wget https://artifacts.chirpstack.io/vendor/multitech/conduit/chirpstack-gateway-bridge_3.1.0-r1_arm926ejste.ipk
however, always an error says :
ERROR: The certificate of ‘artifacts.chirpstack.io’ is not trusted.
ERROR: The certificate of ‘artifacts.chirpstack.i’ is not yet activated.b
whenever I try to setup chirpstack gateway bridge or packet forwarder
please, help
Thank you .
