At the page:
https://www.loraserver.io/lora-gateway-os/use/getting-started/
The text near the beginning reads:
Unlike the lora-gateway-os-base image, you should not update the LoRa Gateway Bridge configuration. It is configured to point to the MQTT broker which comes with the lora-gateway-os-base image.
This does not make any sense, maybe it means to say this:
Unlike the lora-gateway-os-base image, you should not update the LoRa Gateway Bridge configuration. It is configured to point to the MQTT broker which comes with the lora-gateway-os-full image.
Or am I misunderstanding something?
