Hi there.
I used the Hex code “8200” to disable the buzzer on the T1000-A from SenseCAP.
It was successfully sent from the queue, and everything is working fine. I then switched back to “None” in the “Codec” tab, as I don’t need confirmation messages.
Since then, I have been getting the error message “UnconfirmedDataUP” (see below), as well as “UnconfirmedDataDown”.
Thank you for your help.
- m_type:“UnconfirmedDataUp”
- major:“LoRaWANR1”
mic: 4 items
* 0:17
* 1:13
* 2:143
* 3:255
payload:{} 3 keys
* f_port:0
fhdr:{} 4 keys
* devaddr:“4800081e”
* f_cnt:10
f_ctrl:{} 6 keys
* ack:false
* adr:true
* adr_ack_req:false
* class_b:false
* f_opts_len:0
* f_pending:false
* f_opts: 0 items
frm_payload: 1 item
0:{} 1 key
LinkADRAns:{} 3 keys
* ch_mask_ack:true
* dr_ack:true
* tx_power_ack:true
rx_info: 1 item
0:{} 9 keys
* context:“7SM2GA==”
* crcStatus:“CRC_OK”
* gatewayId:“f96997857975cefa”
* gwTime:“2025-01-28T20:45:08.075+00:00”
metadata:{} 9 keys
* gateway_h3index:“8c1fb460c9837ff”
* gateway_id:“11tcwZXaUg43ULmRz6PM9aJmdKVTfJVsY4xqagQSKVVscuHBYSy”
* gateway_lat:“48.825070580129015”
* gateway_long:“2.237454549007108”
* gateway_name:“high-vermilion-wolf”
* network:“helium_iot”
* regi:“EU868”
* region_common_name:“EU868”
* region_config_id:“eu868”
* nsTime:“2025-01-28T20:45:08.160350806+00:00”
* rssi:-86
* snr:14.5
* uplinkId:52883
tx_info:{} 2 keys
- frequency:867900000
modulation:{} 1 key
lora:{} 3 keys
* bandwidth:125000
* codeRate:“CR_4_5”
* spreadingFactor:7
