my goal is to integrate my LoRa sensors into an InfluxDB, so I can use the data from there for my Home Assistant.
Setup
I do the following steps:
- Set up InfluxDB as Docker container on my server. The DB is running and I can log in.
- Configure the integration for my
Sensorsapplication in ChirpStack
- Add an example codec for one test device in my application
Sensors
function decodeUplink(Port, Bytes)
return { data: {
"temperature": 22.5
- Add a dummy device with the codec from above which sends a message every minute. The message is processed without an issue
Question
In which table, etc. are the data from ChirpStack stored in my InfluxDB? I can see the Sensors table with a lot of stuff in it, but I have no idea how to understand this stuff.
