Hey guys,
I’m doing some tests using an STM32WL with the firmware example ST.COM.
At first it has worked reasonably well but I would like to understand why the first 3 to 5 DOWNLINK FRAMES, after performing a JOIN OTTA have the status of unconfirmed.
After that it seems that everything is normalized and the DOWNLINK FRAMES are confirmed.
I’m putting a LOG of LORAWAN-END-NODE. Note that in 2 cases after JOIN OTTA, we have unconfirmed FRAMES.
I’ve done several tests and the same issue always happens.
In this case the Time period between two Tx is 30 seconds, and that doesn’t cause any serious problem but when we increase it to a period of 1 hour or 3 hours this has also happened and is not desirable.
If anyone has gone through this and can help me I would appreciate it.
<\n>APP_VERSION: V1.1.0<\r>
<\n>MW_LORAWAN_VERSION: V2.3.0<\r>
<\n>MW_RADIO_VERSION: V1.1.0<\r>
<\n>###### OTAA ######<\r>
<\n>###### AppKey: 16:9C:63:B7:9E:64:E7:5D:99:2A:C9:BC:8F:AF:A4:B6<\r>
<\n>###### NwkKey: 16:9C:63:B7:9E:64:E7:5D:99:2A:C9:BC:8F:AF:A4:B6<\r>
<\n>###### ABP ######<\r>
<\n>###### AppSKey: 2B:7E:15:16:28:AE:D2:A6:AB:F7:15:88:09:CF:4F:3C<\r>
<\n>###### NwkSKey: 2B:7E:15:16:28:AE:D2:A6:AB:F7:15:88:09:CF:4F:3C<\r>
<\n>###### DevEui: 4A:37:76:1C:5B:6A:92:65<\r>
<\n>###### AppEui: 01:01:01:01:01:01:01:01<\r>
<\n>###### DevAddr: 00:17:A6:FA<\r>
<\n>0s038:TX on freq 915800000 Hz at DR 2<\r>
<\n>0s412:MAC txDone<\r>
<\n>5s397:RX_1 on freq 925100000 Hz at DR 10<\r>
<\n>5s494:MAC rxDone<\r>
<\n><\r>
<\n>###### = JOINED = OTAA =====================<\r>
<\n><\r>
<\n>###### ========== MCPS-Indication ==========<\r>
<\n>###### D/L FRAME:0000 | SLOT:1 | PORT:0 | DR:0 | RSSI:-35 | SNR:8<\r>
<\n>40s041:temp= 22<\n><\r>
40s045:TX on freq 916000000 Hz at DR 2<\r>
<\n>40s047:SEND REQUEST<\r>
<\n>40s418:MAC txDone<\r>
<\n>41s404:RX_1 on freq 925700000 Hz at DR 10<\r>
<\n>41s510:MAC rxDone<\r>
<\n><\r>
<\n>###### ========== MCPS-Confirm =============<\r>
<\n>###### U/L FRAME:0001 | PORT:2 | DR:2 | PWR:0 CONFIRMED [ACK]<\r>
<\n><\r>
<\n>###### D/L FRAME:0000 | SLOT:1 | PORT:0 | DR:10 | RSSI:-34 | SNR:8<\r>
<\n>80s041:temp= 22<\n><\r>
80s045:TX on freq 915400000 Hz at DR 2<\r>
<\n>80s047:SEND REQUEST<\r>
<\n>80s377:MAC txDone<\r>
<\n>81s363:RX_1 on freq 923900000 Hz at DR 10<\r>
<\n>81s469:MAC rxDone<\r>
<\n><\r>
<\n>###### U/L FRAME:0002 | PORT:2 | DR:2 | PWR:0 UNCONFIRMED<\r>
<\n><\r>
<\n>###### D/L FRAME:0001 | SLOT:1 | PORT:0 | DR:10 | RSSI:-33 | SNR:8<\r>
<\n>120s041:temp= 23<\n><\r>
120s045:TX on freq 916400000 Hz at DR 2<\r>
<\n>120s047:SEND REQUEST<\r>
<\n>120s377:MAC txDone<\r>
<\n>121s363:RX_1 on freq 926900000 Hz at DR 10<\r>
<\n>121s469:MAC rxDone<\r>
<\n><\r>
<\n>###### U/L FRAME:0003 | PORT:2 | DR:2 | PWR:0 UNCONFIRMED<\r>
<\n><\r>
<\n>###### D/L FRAME:0002 | SLOT:1 | PORT:0 | DR:10 | RSSI:-34 | SNR:9<\r>
<\n>160s041:temp= 24<\n><\r>
160s045:TX on freq 915200000 Hz at DR 2<\r>
<\n>160s047:SEND REQUEST<\r>
<\n>160s377:MAC txDone<\r>
<\n>161s363:RX_1 on freq 923300000 Hz at DR 10<\r>
<\n>161s469:MAC rxDone<\r>
<\n><\r>
<\n>###### U/L FRAME:0004 | PORT:2 | DR:2 | PWR:0 UNCONFIRMED<\r>
<\n><\r>
<\n>###### D/L FRAME:0003 | SLOT:1 | PORT:0 | DR:10 | RSSI:-40 | SNR:9<\r>
<\n>200s041:temp= 23<\n><\r>
200s045:TX on freq 915600000 Hz at DR 2<\r>
<\n>200s047:SEND REQUEST<\r>
<\n>200s377:MAC txDone<\r>
<\n>201s363:RX_1 on freq 924500000 Hz at DR 10<\r>
<\n>201s413:IRQ_RX_TX_TIMEOUT<\r>
<\n>201s414:MAC rxTimeOut<\r>
<\n>202s375:RX_2 on freq 923300000 Hz at DR 8<\r>
<\n>202s441:IRQ_RX_TX_TIMEOUT<\r>
<\n>202s441:MAC rxTimeOut<\r>
<\n><\r>
<\n>###### U/L FRAME:0005 | PORT:2 | DR:2 | PWR:0 UNCONFIRMED<\r>
<\n>240s041:temp= 23<\n><\r>
240s045:TX on freq 916200000 Hz at DR 2<\r>
<\n>240s047:SEND REQUEST<\r>
<\n>240s418:MAC txDone<\r>
<\n>241s404:RX_1 on freq 926300000 Hz at DR 10<\r>
<\n>241s490:MAC rxDone<\r>
<\n><\r>
<\n>###### U/L FRAME:0006 | PORT:2 | DR:2 | PWR:0 CONFIRMED [ACK]<\r>
<\n><\r>
<\n>###### D/L FRAME:0004 | SLOT:1 | PORT:0 | DR:10 | RSSI:-41 | SNR:10<\r>
<\n>280s041:temp= 23<\n><\r>
280s045:TX on freq 916600000 Hz at DR 2<\r>
<\n>280s047:SEND REQUEST<\r>
<\n>280s418:MAC txDone<\r>
<\n>281s404:RX_1 on freq 927500000 Hz at DR 10<\r>
<\n>281s490:MAC rxDone<\r>
<\n><\r>
<\n>###### U/L FRAME:0007 | PORT:2 | DR:2 | PWR:0 CONFIRMED [ACK]<\r>
<\n><\r>
<\n>###### D/L FRAME:0005 | SLOT:1 | PORT:0 | DR:10 | RSSI:-36 | SNR:9<\r>
<\n>320s041:temp= 23<\n><\r>
320s045:TX on freq 916600000 Hz at DR 2<\r>
<\n>320s047:SEND REQUEST<\r>
<\n>320s418:MAC txDone<\r>
<\n>321s404:RX_1 on freq 927500000 Hz at DR 10<\r>
<\n>321s490:MAC rxDone<\r>
<\n><\r>
<\n>###### U/L FRAME:0008 | PORT:2 | DR:2 | PWR:0 CONFIRMED [ACK]<\r>
<\n><\r>
<\n>###### D/L FRAME:0006 | SLOT:1 | PORT:0 | DR:10 | RSSI:-35 | SNR:10<\r>
<\n>360s041:temp= 23<\n><\r>
360s045:TX on freq 915200000 Hz at DR 2<\r>
<\n>360s047:SEND REQUEST<\r>
<\n>360s418:MAC txDone<\r>
<\n>361s404:RX_1 on freq 923300000 Hz at DR 10<\r>
<\n>361s490:MAC rxDone<\r>
<\n><\r>
<\n>###### U/L FRAME:0009 | PORT:2 | DR:2 | PWR:0 CONFIRMED [ACK]<\r>
<\n><\r>
<\n>###### D/L FRAME:0007 | SLOT:1 | PORT:0 | DR:10 | RSSI:-35 | SNR:9<\r>
<\n>400s041:temp= 23<\n><\r>
400s045:TX on freq 916000000 Hz at DR 2<\r>
<\n>400s047:SEND REQUEST<\r>
<\n>400s418:MAC txDone<\r>
<\n>401s404:RX_1 on freq 925700000 Hz at DR 10<\r>
<\n>401s490:MAC rxDone<\r>
<\n><\r>
<\n>###### U/L FRAME:0010 | PORT:2 | DR:2 | PWR:0 CONFIRMED [ACK]<\r>
<\n><\r>
<\n>###### D/L FRAME:0008 | SLOT:1 | PORT:0 | DR:10 | RSSI:-39 | SNR:8<\r>
<\n>440s041:temp= 23<\n><\r>
440s045:TX on freq 915600000 Hz at DR 2<\r>
<\n>440s047:SEND REQUEST<\r>
<\n>440s418:MAC txDone<\r>
<\n>441s404:RX_1 on freq 924500000 Hz at DR 10<\r>
<\n>441s490:MAC rxDone<\r>
<\n><\r>
<\n>###### U/L FRAME:0011 | PORT:2 | DR:2 | PWR:0 CONFIRMED [ACK]<\r>
<\n><\r>
<\n>0s038:TX on freq 915400000 Hz at DR 2<\r>
<\n>5s397:RX_1 on freq 923900000 Hz at DR 10<\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0000 | SLOT:1 | PORT:0 | DR:0 | RSSI:-35 | SNR:9<\r>
<\n>40s041:temp= 25<\n><\r>
<\n>41s404:RX_1 on freq 924500000 Hz at DR 10<\r>
<\n><\r>
<\n><\r>
<\n>80s041:temp= 25<\n><\r>
80s045:TX on freq 916400000 Hz at DR 2<\r>
<\n>81s363:RX_1 on freq 926900000 Hz at DR 10<\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0001 | SLOT:1 | PORT:0 | DR:10 | RSSI:-47 | SNR:8<\r>
<\n>120s041:temp= 25<\n><\r>
120s045:TX on freq 916200000 Hz at DR 2<\r>
<\n>121s363:RX_1 on freq 926300000 Hz at DR 10<\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0002 | SLOT:1 | PORT:0 | DR:10 | RSSI:-48 | SNR:9<\r>
160s045:TX on freq 915800000 Hz at DR 2<\r>
<\n>161s363:RX_1 on freq 925100000 Hz at DR 10<\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0003 | SLOT:1 | PORT:0 | DR:10 | RSSI:-31 | SNR:9<\r>
<\n>200s041:temp= 25<\n><\r>
200s045:TX on freq 916000000 Hz at DR 2<\r>
<\n>201s363:RX_1 on freq 925700000 Hz at DR 10<\r>
<\n><\r>
<\n>240s041:temp= 25<\n><\r>
240s045:TX on freq 916600000 Hz at DR 2<\r>
<\n>241s404:RX_1 on freq 927500000 Hz at DR 10<\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0004 | SLOT:1 | PORT:0 | DR:10 | RSSI:-36 | SNR:9<\r>
<\n>280s041:temp= 25<\n><\r>
280s045:TX on freq 915200000 Hz at DR 2<\r>
<\n>281s404:RX_1 on freq 923300000 Hz at DR 10<\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0005 | SLOT:1 | PORT:0 | DR:10 | RSSI:-45 | SNR:9<\r>
<\n>320s041:temp= 25<\n><\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0006 | SLOT:1 | PORT:0 | DR:10 | RSSI:-35 | SNR:9<\r>
<\n>360s041:temp= 25<\n><\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0007 | SLOT:1 | PORT:0 | DR:10 | RSSI:-40 | SNR:9<\r>
<\n>400s041:temp= 25<\n><\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0008 | SLOT:1 | PORT:0 | DR:10 | RSSI:-37 | SNR:9<\r>
<\n>440s041:temp= 24<\n><\r>
440s045:TX on freq 915400000 Hz at DR 2<\r>
<\n>441s404:RX_1 on freq 923900000 Hz at DR 10<\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0009 | SLOT:1 | PORT:0 | DR:10 | RSSI:-39 | SNR:9<\r>
<\n>480s041:temp= 24<\n><\r>
480s045:TX on freq 916400000 Hz at DR 2<\r>
<\n>480s047:SEND REQUEST<\r>
<\n>480s418:MAC txDone<\r>
<\n>481s404:RX_1 on freq 926900000 Hz at DR 10<\r>
<\n>481s490:MAC rxDone<\r>
<\n><\r>
<\n>###### U/L FRAME:0012 | PORT:2 | DR:2 | PWR:0 CONFIRMED [ACK]<\r>
<\n><\r>
<\n>###### D/L FRAME:0010 | SLOT:1 | PORT:0 | DR:10 | RSSI:-33 | SNR:9<\r>
<\n>520s041:temp= 24<\n><\r>
520s045:TX on freq 915800000 Hz at DR 2<\r>
<\n>520s047:SEND REQUEST<\r>
<\n>520s418:MAC txDone<\r>
<\n>521s404:RX_1 on freq 925100000 Hz at DR 10<\r>
<\n>521s490:MAC rxDone<\r>
<\n><\r>
<\n>###### U/L FRAME:0013 | PORT:2 | DR:2 | PWR:0 CONFIRMED [ACK]<\r>
<\n><\r>
<\n>###### D/L FRAME:0011 | SLOT:1 | PORT:0 | DR:10 | RSSI:-45 | SNR:9<\r>
UPDATING…
I did some other tests checking the ACK via MQTT…
NETWORK-SERVER
MQTT:
mosquitto_sub -t gateway/b5b40f0f5b515755/event/ack -v
gateway/b5b40f0f5b515755/event/ack {“gatewayID”:“tbQPD1tRV1U=”,“token”:17158,“error”:"",“downlinkID”:“yczykZmYQB6X89uP/tcHQw==”,“items”:[{“status”:“OK”},{“status”:“IGNORED”}]}
gateway/b5b40f0f5b515755/event/ack {“gatewayID”:“tbQPD1tRV1U=”,“token”:52511,“error”:"",“downlinkID”:“zR9WaobSRKepKBcY8HxH7w==”,“items”:[{“status”:“OK”},{“status”:“IGNORED”}]}
gateway/b5b40f0f5b515755/event/ack {“gatewayID”:“tbQPD1tRV1U=”,“token”:23343,“error”:"",“downlinkID”:“Wy8Pr+g2Qzmc0wzYuWjLdw==”,“items”:[{“status”:“OK”},{“status”:“IGNORED”}]}
gateway/b5b40f0f5b515755/event/ack {“gatewayID”:“tbQPD1tRV1U=”,“token”:46811,“error”:"",“downlinkID”:“ttuneDykTveCuzUmZ/m4Aw==”,“items”:[{“status”:“OK”},{“status”:“IGNORED”}]}
gateway/b5b40f0f5b515755/event/ack {“gatewayID”:“tbQPD1tRV1U=”,“token”:40433,“error”:"",“downlinkID”:“nfFcCRfUSzuLTCM8TOhPcQ==”,“items”:[{“status”:“OK”},{“status”:“IGNORED”}]}
gateway/b5b40f0f5b515755/event/ack {“gatewayID”:“tbQPD1tRV1U=”,“token”:51262,“error”:"",“downlinkID”:“yD4D/5yIRsmAUNgfcXHwTw==”,“items”:[{“status”:“OK”},{“status”:“IGNORED”}]}
END-NODE:
<\n>0s038:TX on freq 916600000 Hz at DR 2<\r>
<\n>5s397:RX_1 on freq 927500000 Hz at DR 10<\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0000 | SLOT:1 | PORT:0 | DR:0 | RSSI:-41 | SNR:8<\r>
<\n>40s041:temp= 27<\n><\r>
40s044:TX on freq 916000000 Hz at DR 2<\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0000 | SLOT:1 | PORT:0 | DR:10 | RSSI:-42 | SNR:9<\r>
<\n>80s041:temp= 28<\n><\r>
80s045:TX on freq 915800000 Hz at DR 2<\r>
<\n>81s363:RX_1 on freq 925100000 Hz at DR 10<\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0001 | SLOT:1 | PORT:0 | DR:10 | RSSI:-36 | SNR:8<\r>
<\n>120s041:temp= 27<\n><\r>
120s045:TX on freq 915400000 Hz at DR 2<\r>
<\n>121s363:RX_1 on freq 923900000 Hz at DR 10<\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0002 | SLOT:1 | PORT:0 | DR:10 | RSSI:-36 | SNR:9<\r>
<\n>160s041:temp= 27<\n><\r>
<\n><\r>
<\n><\r>
<\n>###### D/L FRAME:0003 | SLOT:1 | PORT:0 | DR:10 | RSSI:-37 | SNR:8<\r>
<\n>200s041:temp= 26<\n><\r>
<\n><\r>
<\n>240s041:temp= 27<\n><\r>
<\n><\r>
<\n><\r>
<\n>
