Sorry for the stupid question and I’ll answer it myself if I figure it out.
I followed the instructions on how to install CS and I have a Tektelic Kona macro gateway, which is also running the gateway bridge (the best way to do it I figured). CS kept saying the gateway has never been seen so I think I finally realized that the gateway bridge is running on the gateway and on the CS server (Ubuntu). I definitely have the chirpstack-gateway-bridge.toml on the server.
In my limited knowledge I figured the gateway bridge on the gateway can’t connect because the port is already occupied by the other one. With the gateway powered off and the server rebooted I see these ports:
$ ss | grep 1883
tcp ESTAB 0 0 127.0.0.1:1883 127.0.0.1:53910
tcp ESTAB 0 0 127.0.0.1:53914 127.0.0.1:1883
tcp ESTAB 0 0 127.0.0.1:1883 127.0.0.1:53914
tcp ESTAB 0 0 127.0.0.1:53920 127.0.0.1:1883
tcp ESTAB 0 0 127.0.0.1:1883 127.0.0.1:53920
tcp ESTAB 0 0 127.0.0.1:53910 127.0.0.1:1883
Before I screw up anything else, what is the best way to turn off the gateway bridge on the server?
Many thanks for any help.
