Hi all
Fresh clean Ubuntu 20.04.6 server, running these Chirpstack versions
application server - 3.17.9
network server - 3.16.8
gateway version bridge - 4.0.10
Using a brand new Dragino LPSD8N
Issue I am facing is constant “unmarshal uplink frame error” and “unmarshal gateway stats error”, all stating “cannot parse invalid wire-format data”
Example error messages:
Feb 01 10:49:44 username chirpstack-network-server[860]: time="2024-02-01T10:49:44.318553492Z" level=error msg="gateway/mqtt: unmarshal uplink frame error" data_base64=eyJwaHlQYXlsb2FkIjoiQUFFQUtnREFKT0VrRjVJWlBIRWs0U1NWSjZZaDFoMD0iLCAidHhJbmZvIjp7ImZyZXF1ZW5jeSI6ODY4MTAwMDAwLCAibW9kdWxhdGlvbiI6eyJsb3JhIjp7ImJhbmR3aWR0aCI6MTI1MDAwLCAic3ByZWFkaW5nRmFjdG9yIjoxMCwgImNvZGVSYXRlIjoiQ1JfNF81In19fSwgInJ4SW5mbyI6eyJnYXRld2F5SWQiOiJhODQwNDFmZmZmMjY4MGI4IiwgInVwbGlua0lkIjoyMTAxNCwgInRpbWUiOiIyMDEyLTAxLTAxVDAwOjE5OjA4LjM4NjMxMVoiLCAicnNzaSI6LTEyLCAic25yIjoxMywgInJmQ2hhaW4iOjEsICJjb250ZXh0IjoiQVROUmVnPT0iLCAiY3JjU3RhdHVzIjoiQ1JDX09LIn19 error="proto: cannot parse invalid wire-format data"
Feb 01 10:49:51 username chirpstack-network-server[860]: time="2024-02-01T10:49:51.477799232Z" level=error msg="gateway/mqtt: unmarshal uplink frame error" data_base64=eyJwaHlQYXlsb2FkIjoiQUFFQUtnREFKT0VrRjVJWlBIRWs0U1RXa3pUT1JsOD0iLCAidHhJbmZvIjp7ImZyZXF1ZW5jeSI6ODY4NTAwMDAwLCAibW9kdWxhdGlvbiI6eyJsb3JhIjp7ImJhbmR3aWR0aCI6MTI1MDAwLCAic3ByZWFkaW5nRmFjdG9yIjoxMCwgImNvZGVSYXRlIjoiQ1JfNF81In19fSwgInJ4SW5mbyI6eyJnYXRld2F5SWQiOiJhODQwNDFmZmZmMjY4MGI4IiwgInVwbGlua0lkIjoxMjI2OSwgInRpbWUiOiIyMDEyLTAxLTAxVDAwOjE5OjE1LjU0NjExMloiLCAicnNzaSI6LTEzLCAic25yIjoxMC4yLCAiY2hhbm5lbCI6MiwgInJmQ2hhaW4iOjEsICJjb250ZXh0IjoiQWFDTHVnPT0iLCAiY3JjU3RhdHVzIjoiQ1JDX09LIn19 error="proto: cannot parse invalid wire-format data"
I can’t figure out how to fix it as all I have is a single gateway, I don’t even have sensors online at this point.
If anyone has any idea how I can fix it that would be amazing thanks!
