Is it possible to update data on two end devices in one request via api?
for ex.
http://127.0.0.1:8080/api/devices/devEUI&devEUI??
body:
"device": {
"applicationID": "14",
"description": "1",
"devEUI": "222222222",
"deviceProfileID": "222",
"isDisabled": false,
"name": "1"
"device": {
"description": "App",
"devEUI": "111111",
"deviceProfileID": "123",
"name": "App"
use CURL to do that, if you using *nix based OS wih this tool. for example.
eugenev could you write an example of how it will look through CURL??
just use the man curl in your *nix machine or go to curl(1) - Linux manual page
I’m tedious to add, for example, 5 devices in one request. could you give an example,so that there are not 5 separate requests to the server
each request must be separate for each endnode and does not imply a group action on all at once. or write your own script that executes the batch job.
Is there any limit on the number of requests in a short time? for example it will be possible to make 100 requests one after another?
Hey @annalupanova1999 ,
Where REST API integration refers to connecting with third-party applications using HTTPS requests to access and transmit data .
