Uplink Codec Error
Hi, I´m new with this things. We are testing a distance sensor but I have trouble with the data that we received.
Sometimes I get this message: ¨Exception generated by quickjs: interrupted¨
Also, sometimes I receive this message: * “Uplink was flagged as re-transmission / frame-counter did not increment”
How can I solve this problems?
This is the codec
 * Payload Decoder for Chirpstack and Milesight network server
 * Copyright 2023 Milesight IoT
 * @product EM400-UDL
function decodeUplink({fPort, bytes}) {
    var decoded= {data:{},
    for (var i = 0; i < bytes.length; ) {
        var channel_id = bytes[i++];
        var channel_type = bytes[i++];
        // BATTERY
        if (channel_id === 0x01 && channel_type === 0x75) {
            decoded.data.battery = bytes[i];
            i += 1;
        // TEMPERATURE
        else if (channel_id === 0x03 && channel_type === 0x67) {
            decoded.data.temperature = readInt16LE(bytes.slice(i, i + 2)) / 10;
            i += 2;
        // DISTANCE
        else if (channel_id === 0x04 && channel_type === 0x82) {
            decoded.data.distance = readUInt16LE(bytes.slice(i, i + 2));
            i += 2;
        // POSITION
        else if (channel_id === 0x05 && channel_type === 0x00) {
            decoded.data.position = bytes[i] === 0 ? "normal" : "tilt";
            i += 1;
        // TEMPERATURE WITH ABNORMAL
        else if (channel_id === 0x83 && channel_type === 0x67) {
            decoded.data.temperature_abnormal = bytes[i + 2] == 0 ? false : true;
            i += 3;
        // DISTANCE WITH ALARMING
        else if (channel_id === 0x84 && channel_type === 0x82) {
            decoded.data.distance_alarming = bytes[i + 2] == 0 ? false : true;
            i += 3;
        } else {
            break;
    return decoded;
 * bytes to number
function readUInt16LE(bytes) {
    var value = (bytes[1] << 8) + bytes[0];
    return value & 0xffff;
function readInt16LE(bytes) {
    var ref = readUInt16LE(bytes);
    return ref > 0x7fff ? ref - 0x10000 : ref;
