Hi team,
I am facing a new strange issue which I don’t know how to troubleshoot. Our sensors are configured to send uplink in fport 2, but the uplink is sent via both fport2 where I have my payload and most of the time in fPort0 where my data is null, may I know why the uplink is being sent to fPort0 when it is about to send all uplink via fPort2 ?? I have checked the console logs of end device, it is sending in fPort2 but LNS side it is showing fPort0…Thanks, Please help
Hi, I have seen fport0 with null data when device exceeds the maimum payload size for given datarate. I did not really dig into why is that as the primary problem is obviously the device sending more data than allowed.
Thanks for the reply, My gateway is receiving the proper data from the node but when it comes to LNS, I am facing this issue , I have attached the logs of the gateway and the chirpsack LNS below, the LNS is not getting the payload and the value is in fport 0
gateway Log:
Mar 17 04:01:25 Wirnet local1.notice spf: INFO: Received pkt from mote: 0144B2D1 (fcnt=8082)
Mar 17 04:01:25 Wirnet local1.notice spf: JSON up: {“rxpk”:[{“tmst”:2886157884,“chan”:7,“rfch”:1,“freq”:923.400000,“stat”:1,“modu”:“LORA”,“datr”:“SF10BW125”,“codr”:“4/5”,“lsnr”:11.8,“rssi”:-70,“size”:19,“data”:“QNGyRAGAkh8A0xMqt0ZMU34lZQ==”}]}
Mar 17 04:01:25 Wirnet local1.notice spf: INFO: [up] PUSH_ACK received in 2 ms
Mar 17 04:01:25 Wirnet local1.notice spf: INFO: [down] PULL_RESP received - token[29:219]
Mar 17 04:01:25 Wirnet local1.notice spf: JSON down: {“txpk”:{“imme”:false,“rfch”:0,“powe”:14,“ant”:0,“brd”:0,“tmst”:2887157884,“freq”:923.4,“modu”:“LORA”,“datr”:“SF10BW125”,“codr”:“4/5”,“ipol”:true,“size”:24,“data”:“YNGyRAGMHx8NMER8TZcDUwcAAQa7V0hl”}}
Chirpstack LNS Log:
"type": "uplink",
"payload": {
"adr": true,
"applicationID": "1",
"applicationName": "sptel-app-2",
"data": null,
"devEUI": "0a0101010101010a",
"deviceName": "ratsensenew1",
"fCnt": 8082,
"fPort": 0,
"object": {
"battery": "NaN",
"hum": "NaN",
"period": "0 sec",
"temp": "-46.85"
"rxInfo": [
"gatewayID": "7276ff000b031eba",
"loRaSNR": 11.8,
"location": {
"altitude": 0,
"latitude": 1.390624,
"longitude": 103.846459
"name": "slioilc000lg001-2037",
"rssi": -70,
"uplinkID": "345c41ef-c62c-42ff-b1c7-0ced2ec6c01f"
"txInfo": {
"dr": 2,
"frequency": 923400000
Please help, I am struggling with this issue for long time
Hi @spiot and all
I am facing a similar problem that chirpstack receives packet from my end device with data = null through fport 0, while my device is configured to send data through fport2.
I’ve setup a LoRaWan gateway with the things Network(TTN) and it received the payload correctly with fport = 2. The firmware of my end device used for testing on both TTN and Chirpstack were the same.
I wonder how to fix this problem. Do you guys have solution upon this question yet?
It is devastatingly urgent to solve this issue.
Could this be a mac-layer related uplink? fport = 0 indicates that the frmpayload must be interpreted as mac-commands. In this case an up event is exposed to the end-application (without any data) as the RX related meta-data can still be useful to collect for the end-application.
