Is it possible to send data directly to the gateway over MQTT or any other means via gateway bridge?
According to the architecture diagram, network-server uses MQTT to communicate with the gateway bridge which then sends the data to the gateway (Laird). However, when I watch the gateway/id/commands/+ topic, I don’t see any data. How does network server communicate with the gateways?
I assume it is just as simple as publishing to gateway/id/command/down to schedule a downlink?
There is a lot to see if you watch all gateway topics (gateway/#): https://www.chirpstack.io/gateway-bridge/payloads/
Note that by default it is in protobuf format (compact, faster), so you may want to switch gateway and NS to JSON if you want something human-readable for perusing.
