I would like to use the GatewayOS with an external gateway (MikroTik-aWP8) and I don’t have LoraShield installed on the RaspberryPi.
Installing the image, adding the network server and setting up the gateway worked. Unfortunately both systems do not connect.
Question before I look for the error. Is it at all possible to use the GatewayOS without a shield with an external gateway. The ChirpStack Concentratord reports under the Monit status “cannot connect”. Which is correct. If so, do I have to configure the MQTT broker differently?
Actually I pass my packets to the network server via port 1700.
So far I have not found such a combination in the forum. Therefore I am unsure if this works at all.
Thanks for help,
