I installed the Chirpstack stack following the GCP guide (Quickstart Google Cloud Platform - ChirpStack open-source LoRaWAN<sup>®</sup> Network Server). The bridge is installed on the gateways.
I did not install the TLS certificates (GitHub - chirpstack/chirpstack-certificates: Scripts to generate certificates for the ChirpStack components.) because everything is on a private network and the only public component is the application server. I secured the access to the application server with LetsEncrypt.
Now I would like to use the javascript SDK to call the API (https://www.npmjs.com/package/@chirpstack/chirpstack-api). I try to get a device with the following snippet:
const grpc = require('grpc');
const nsDeviceService = require('@chirpstack/chirpstack-api/as/external/api/device_grpc_pb');
const { GetDeviceRequest } = require('@chirpstack/chirpstack-api/as/external/api/device_pb');
const deviceServiceClient = new nsDeviceService.DeviceServiceClient(
'<DOMAIN>',
grpc.credentials.createSsl(),
const metadata = new grpc.Metadata();
metadata.set(
'authorization',
'Bearer <API_TOKEN>'
const reqArgs = new GetDeviceRequest();
reqArgs.setDevEui("<DEVEUI>");
deviceServiceClient.get(reqArgs, metadata, (error, response) => {
if (error) {
console.error(error);
} else {
console.log("it works!");
I get the following error:
Error: 1 CANCELLED: Received http2 header with status: 404
I get the same error if I add the port number (i.e.: :443).
If I try it using grps.credentials.createInsecure()
, I get this error:
Error: 14 UNAVAILABLE: Trying to connect an http1.x server
I am able to call the API using cURL or the swagger page, so I don’t understand why I get this problem.
Could someone please help me?
