Using tags / variables in Codec
Hi everyone!
Is it possible to make usage of the tags / variables of a device in the device codec? I would like to add some more logic to the decoder before I forward the data to my Application…
Regards
No, (currently) the only input to the codec is the fPort and an array of bytes.
Hi everyone,
Thanks brocaar for your information.
Can you give me a example of the use of a variable in HTTP integration. When I add a tag then I see it in the payload. But when I define a variable I see nothing have changed in the payload. We want to use one device profile for all door sensors, but we need to know which sensor is open or closed in out application.
Best Regards
Gerard
The variables are used to store for example the ThingsBoards key for each device, these are not exposed in the payload. In that case use the tags.
