Hello, ChirpStack Support Team.
I attempted to flash the ChirpStack Gateway OS images, but none of them booted. Could you please help me?
I’m using a Raspberry Pi 5, and I tested the Raspberry Pi 4B full and base images, as well as all but the Raspberry Pi Zero W images, with Balena and Win32DiskImager, both zipped and unzipped image files.
I’m using a 4GB Raspberry Pi 5 with an 11" monitor.
I tried every image source, even on Raspberry Pi 2W
I used Balena, Win32 DiskImager, and the Raspberry Pi Imager.
I utilized both zipped and unzipped image sources.
Raspberry won’t boot; however, if I install Raspberry Pi OS 64-bit on a desktop, I can always connect to it over SSH from Windows 11.
A question: When installing the Raspberry Pi OS, I use the 64-bit OS with a desktop; I’ve also tried both 64 and 32 bits, with and without a desktop. It is OK if I always use 64 bits? With desktop or without it?
You will be quite helpful to me; I have spent a significant amount of time attempting to make it work.
It should work may be your doing something wrong .well alternative you can run book worm and install all the modules like chirpstack -concertrator ,chirpstack
mqtt forwarder and chirpstack its easy follow the documentation.
