I’m trying to send a mqtt downlink message via node red mqtt. It works in v3 so I can see the message queued waiting for an uplink message. If I try to do the same in v4 I don’t see the message queued inside the device application. What I’m doing wrong?
This is the topic
application/xxxxxxxx-91fe-41e8-85d1-1ec497ee32be/device/58a0cb0000108d64/command/down
Hi, I am testing v4 now and I am trying to send downlinks using mqtt. The format you are proposing here, does not work and is also not what is used in the documentation. Having said that, the documented method is also not working for me. Did you get this working?
