The influxdb integration will revert to display the v1 form if using the v2 form. This is confusing as you can not make changes unless you swap it to v2 and v1 again. It is also confusing as I am unsure if it saved correctly because it is requesting a text for “databases” which is not used in v2.
Could you please create a GitHub issue for this? The forum is not a really good place to keep track of reported bugs If you can, please provide steps how to reproduce the issue.
