Visualizing application data
Hi @brocaar I used loraserver-docker github code compiled it running good.Thanks to your guidelines and documentation.
Now I am trying to add one more page.
For Example: If i want an pie chart or I want to plot a graph of my stored values, Is it possible to add one or more page in loraserver web page using docker provided environment or no ?
If no then is there anyway can i do ?
and
If yes then how can i do ?
Please help me doing this.
Thank you,
Sadashiv
This is not something that the App Server will do for you, but you can do this in for example Grafana or Thingsboard.
This Link didn’t worked for me @brocaar sir
The link you mentioned β€œhttps://github.com/brocaar/lora-app-server/tree/influx_integration” says error not found. Have you updated the LoRa-app-server source file??
It is because this feature has been released and the feature branch has been removed.
Thank You for the reply @brocaar sir.
Now, How can i implement influxdb and Grafana in order to fetch my data and see as Graph like structure?
Thank You
You can create beautiful visualization without coding. Here is a sample guide on How to Create Pareto Chart in Google Sheets with great graphic to make your visualization sophisticated.
