Hello everyone, who can tell me, my log level is Warning
I get the error
time=“2020-03-25T13:57:48Z” level=warning msg=“grpc: addrConn.createTransport failed to connect to {[::1]:8001 0 }. Err :connection error: desc = "transport: Error while dialing dial tcp [::1]:8001: connect: cannot assign requested address". Reconnecting…”
time=“2020-03-25T13:58:18Z” level=warning msg=“grpc: addrConn.createTransport failed to connect to {[::1]:8001 0 }. Err :connection error: desc = "transport: Error while dialing dial tcp [::1]:8001: connect: cannot assign requested address". Reconnecting…”
time=“2020-03-25T13:58:31Z” level=error msg=“uplink: processing uplink frame error” ctx_id=b933057e-cb99-4bfb-a416-d753dad769a4 error=“get device-session error: object does not exist”
My NS config
[general]
log_level=3
#log_to_syslog=true
[postgresql]
dsn=“postgres://chirpstack_ns:chirpstack_ns@t_data/chirpstack_ns?sslmode=disable”
[redis]
url=“redis://t_data:6379”
[network_server]
net_id=“000000”
[network_server.band]
name=“RU_864_870”
[network_server.api]
bind=“0.0.0.0:8000”
server=“tcp://t_data:1883”
[join_server.default]
server=“http://localhost:8003”
My App config
[postgresql]
dsn=“postgres://chirpstack_as:chirpstack_as@t_data/chirpstack_as?sslmode=disable”
[redis]
[application_server.api]
bind=“0.0.0.0:8001”
public_host=“0.0.0.0:8001”
bind=“0.0.0.0:8080”
jwt_secret=“Secret”
Lora-server + Bridge + App running in a single container “t_lw”
postgresql and redis work in the second container “t_data”
root@t_lw:/# netstat -pantu | grep 8001
tcp 0 0 127.0.0.1:8001 127.0.0.1:33956 TIME_WAIT -
tcp 0 0 127.0.0.1:36838 127.0.0.1:8001 ESTABLISHED 9/chirpstack-networ
tcp6 0 0 :::8001 :::* LISTEN 57/chirpstack-appli
tcp6 0 0 127.0.0.1:8001 127.0.0.1:36838 ESTABLISHED 57/chirpstack-appli
