I’m in the process of building a custom device using the WaveShare PicoHAT:
The example code requires three values:-
- DeviceEUI using LSB value from Chirpstack
- AppEUI/JoinEUI all zeros
- AppKey using MSB value from Chirpstack
The code appears to correct as I’m now seeing the WaveShare device contacting ChirpStack and JoinRequest being displayed by both the Gateway & the Device but the device never joins as an Error is being generated, Code: UPLINK_MIC.
- time:“2023-05-10T14:08:36.553340057+00:00”
- tenantId:“78c266f2-b1de-4509-b46f-e3e86489680d”
- tenantName:“Langford-IT”
- applicationId:“8e747fc9-680e-45d6-98a4-29b46ce23ffe”
- applicationName:“Langford-IT-Rat-Trap”
- deviceProfileId:“53b3e965-92b7-41c6-9dae-157e6e0051bc”
- deviceProfileName:“Waveshare-Pico-Hat”
- deviceName:“Another-Test”
- devEui:“7074140000ab2a45”
- tags:
- level:“ERROR”
- code:“UPLINK_MIC”
- description:“MIC of join-request is invalid, make sure keys are correct”
- deduplication_id:“d7f8ed0e-aa4c-4fe0-932b-c8fb3b46f5a9”
Based on my research this indicates that there’s a problem with my keys, is there anything that I can do to troubleshoot this?
Can this error be caused by the device profile, the one I’ve created is inline with the WaveShare documents. I also have other commercial devices that have connected and are working as planned.
Thanks in advance for any tips or suggestion that will help me resolve this issue.
