Hello, I need help here.
I successfully installed chirpstack and now I’m using the web interface to setup my RAK2287, but when I’m trying to create a device profile I can’t get select the region for the profile.
And when I click on regions it says “No data”.
May be because you have not enabled any region in chirpstack.toml.
Check the enabled_regions in chirpstack.toml.
You need to configure the region_xxx.toml you need also.
https://www.chirpstack.io/docs/chirpstack/configuration.html
This is mine.
