Greetings,
I have a weird error with the ThingsBoard integration. To explain, I have two servers created on DigitalOcean. The first hosts my LoraServer instance and the second hosts my ThingsBoard instance.
The servers each have their own IP address and each ends with :8080.
I followed the steps:
- Add the integration to the application
- Generate the device token on the ThingsBoard UI
- Added the appropriate variable and pasted token in
When looking at the logs I found this message:
*Nov 03 20:25:45 coach-lora-droplet-001 lora-app-server[793]: time=“2019-11-03T20:25:45Z” level=error msg="integration/multi: integration thingsboard.Integration error" error=“send event error: http request error: Post http://xxx.xxx.xx:8080//api/v1/C********************A/attributes: dial tcp: lookup 167.71.30: no such host”
What do you think this means and what steps can be taken to diagnose/fix this?
Cheers,
