This forum is here to help you with LoRaWAN and the LoRa Server project! Before posting questions, don’t forget to check if your question hasn’t already been covered by the project documentation. This documentation is located at https://docs.loraserver.io/. It does not only contain guides to get you started, it also contains links to the latest binaries and source-code
