chirpstack version: 4.0.0-rc.2
chirpstack.toml as follow
# Logging.
[logging]
# Log level.
level="trace"
# PostgreSQL configuration.
[postgresql]
# PostgreSQL DSN.
# SSL mode options:
# * disable - no SSL
dsn="postgres://chirpstack:chirpstack@postgres/chirpstack?sslmode=disable"
# Max open connections.
# PostgreSQL connection pool.
max_open_connections=10
# Min idle connections.
min_idle_connections=0
# Redis configuration.
[redis]
servers=[
"redis://redis/",
# TLS enabled.
tls_enabled=false
# Redis Cluster.
# instance.
cluster=false
[network]
net_id="000000"
# Enabled regions.
enabled_regions=[
"as923_2",
"as923_3",
"as923_4",
"au915_0",
"cn470",
"cn779",
"eu433",
"eu868",
"in865",
"ism2400",
"kr920",
"ru864",
"us915_0",
"us915_1",
[api]
bind="0.0.0.0:8080"
# Secret.
# openssl rand -base64 32
secret="you-must-replace-this"
[gateway]
client_cert_lifetime="365days"
ca_cert="configuration/certs/ca.crt"
ca_key="configuration/certs/ca.key"
[integration]
enabled=["mqtt"]
[integration.mqtt]
server="tcp://mosquitto:1883/"
json=true
[integration.mqtt.client]
cn470.toml as follow
# This file contains an example cn470 configuration.
[[regions]]
# Name is an user-defined identifier for this region.
name="cn470"
# Common-name refers to the common-name of this region as defined by
# the LoRa Alliance.
common_name="CN470"
# Gateway configuration.
[regions.gateway]
# Force gateways as private.
# If enabled, gateways can only be used by devices under the same tenant.
force_gws_private=false
[regions.gateway.backend]
# The enabled backend type.
enabled="mqtt"
# MQTT configuration.
# Event topic template.
event_topic="cn470/gateway/+/event/+"
# Command topic template.
command_topic="cn470/gateway/{{ gateway_id }}/command/{{ command }}"
server="tcp://mosquitto:1883"
username=""
password=""
# Quality of service level
# 0: at most once
# 1: at least once
# 2: exactly once
qos=0
# Clean session
clean_session=false
# Client ID
# a random id will be generated.
client_id=""
ca_cert=""
tls_cert=""
# TLS key file (optional)
tls_key=""
# Gateway channel configuration.
# Note: this configuration is only used in case the gateway is using the
# ChirpStack Concentratord daemon. In any other case, this configuration
# is ignored.
[[regions.gateway.channels]]
frequency=470300000
bandwidth=125000
modulation="LORA"
spreading_factors=[7, 8, 9, 10, 11, 12]
frequency=470500000
bandwidth=125000
modulation="LORA"
frequency=470700000
bandwidth=125000
modulation="LORA"
frequency=470900000
bandwidth=125000
modulation="LORA"
frequency=471100000
bandwidth=125000
modulation="LORA"
frequency=471300000
bandwidth=125000
modulation="LORA"
frequency=471500000
bandwidth=125000
modulation="LORA"
frequency=471500000
bandwidth=125000
modulation="LORA"
# Region specific network configuration.
[regions.network]
# surrounded gateways.
installation_margin=10
# RX window (Class-A).
# Set this to:
# 0: RX1 / RX2
# 1: RX1 only
# 2: RX2 only
rx_window=0
# RX1 delay (1 - 15 seconds).
rx1_delay=1
# RX1 data-rate offset
rx1_dr_offset=0
# RX2 data-rate
rx2_dr=0
# RX2 frequency (Hz)
rx2_frequency=505300000
rx2_prefer_on_rx1_dr_lt=0
# Prefer RX2 on link budget.
# Downlink TX Power (dBm)
# be used.
downlink_tx_power=-1
# ADR is disabled.
adr_disabled=false
# Minimum data-rate.
min_dr=0
# Maximum data-rate.
max_dr=5
# Rejoin-request configuration (LoRaWAN 1.1)
[regions.network.rejoin_request]
# Request devices to periodically send rejoin-requests.
enabled=false
# The device must send a rejoin-request type 0 at least every 2^(max_count_n + 4)
# uplink messages. Valid values are 0 to 15.
max_count_n=0
# The device must send a rejoin-request type 0 at least every 2^(max_time_n + 10)
# seconds. Valid values are 0 to 15.
# 0 = roughly 17 minutes
# 15 = about 1 year
max_time_n=0
# Class-B configuration.
[regions.network.class_b]
# Ping-slot data-rate.
ping_slot_dr=0
# Ping-slot frequency (Hz)
# set this to 0 to use the default frequency plan for the configured region
ping_slot_frequency=0
