I´m using ChirpStack v4 as a Docker container with default settings (except the ports) on my server behind an Nginx. Calling the service via http://<IP>:8580/ is working without an issue (Image 1).
But calling the service via HTTPS leads to a white page in my browser (Image 2).
I don´t understand the message You need to enable JavaScript to run this app. in the development console because JavaScript is enabled for each website (Image 3).
Nginx is using the following settings for the service:
server {
listen [::]:443 ssl;
listen 443 ssl;
server_name name1 name2;
fastcgi_cache FAST_CGI_ZONE_1;
fastcgi_cache_valid 200 60m;
access_log /var/log/nginx/chirpstack_access.log;
error_log /var/log/nginx/chirpstack_error.log;
location / {
proxy_pass http://localhost:8580/;
location ~ ^/api/(gateways|devices)/(\w+)/(frames|events)$ {
limit_req zone=RATE_LIMIT_ZONE_1 burst=5 nodelay;
proxy_pass http://localhost:8580/api/$1/$2/$3/;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
proxy_read_timeout 86400s;
proxy_send_timeout 86400s;
ssl_certificate /etc/letsencrypt/live/server-kampert.de-0001/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/server-kampert.de-0001/privkey.pem; # managed by Certbot
I have also tested Microsoft Edge and the issue is the same. What is the reason for it and how can I fix it?
