I tried many things to make it work but I fail every time and I don’t know why.
Can any one of you send me his différents config files ?
I’ve already managed to connect an NKE smart plug to my NS using a kerlink gateway but i can’t connect it any more…
I just want to be sure of all my config files.
Thank you by advance,
Regards
Maybe you can point out what exactly is failing?
If you want something which (should) work out of the box, try this Docker setup: https://www.loraserver.io/install/docker/.
Update : I tried to install it on an other computer (a Mac) on a virtual machine with Ubuntu 16.04LTS
Everything is fine except that the gateway can’t connect to the gateway bridge.
Using Wireshark I found that the destination port is unreachable even if my packet forwarder configuration is correct and the ping is ok.
I don’t know what to do…
