I’m trying to communicate to a Class C device using downlink. However, I found all my downlink packets were rejected (by the gateway) because the network-server was always requesting transmission at a wrong frequency - 869525000. I have specified by BAND as AS923 in chirpstack-network-server.toml file. The startup log also stated this:
time=“2020-04-29T11:31:14Z” level=info msg=“starting ChirpStack Network Server” band=AS923 docs=“https://www.chirpstack.io/” net_id=000000 version=3.5.0
How do I rectify this problem?
This is the txInfo that I captured using LORAWAN FRAMES - which shows the wrong frequency is used:
- gatewayID:“0505f041c8e3b165”
- frequency:869525000
- power:14
- modulation:“LORA”
loRaModulationInfo:{} 4 keys
- bandwidth:125
- spreadingFactor:12
- codeRate:“4/5”
- polarizationInversion:true
- board:0
- antenna:0
- timing:“IMMEDIATELY”
- immediatelyTimingInfo:{} 0 keys
- context:“MS+ylA==”
