Wrong region for My Gateway UG63
I work for a small company and we want to setup a ChirpStack LoraWAN Network Server.
Our Gateway: Milesight UG63
I use a Docker Desktop and Semtech UDP,
The gateway is stated as Online but somehow the region is eu868. I want the region to become as923 but the error in the log keep giving this
ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 922600000, dr: 5
When I look in the WebGUI on the gateway - LoRaWAN frames tab it is indefinetly loading and I can see nothing. Same happens for the device tab - Events/LoRaWAN frames. It is just loading, but displays nothing.
this is my chirpstack-gateway-bridge.toml:
this is my chirpstack.toml:
Can someone please help me how I can fix those things? How can I change the frequency region of my gateway to as923? Thanks in advance!
Have you changed the topic-prefix in your docker-compose.yml?
This section:
  chirpstack-gateway-bridge:
    image: chirpstack/chirpstack-gateway-bridge:4
    restart: unless-stopped
    ports:
      - 1700:1700/udp
    volumes:
    environment:
      - INTEGRATION__MQTT__EVENT_TOPIC_TEMPLATE=eu868/gateway/{{ .GatewayID }}/event/{{ .EventType }}
      - INTEGRATION__MQTT__STATE_TOPIC_TEMPLATE=eu868/gateway/{{ .GatewayID }}/state/{{ .StateType }}
      - INTEGRATION__MQTT__COMMAND_TOPIC_TEMPLATE=eu868/gateway/{{ .GatewayID }}/command/#
    depends_on:
      - mosquitto
eu868 should be replaced with as923.
yes i did
this is my docker-compose.yml:
services:
  chirpstack:
    image: chirpstack/chirpstack:4
    command: -c /etc/chirpstack
    volumes:
      - ./lorawan-devices:/opt/lorawan-devices
    depends_on:
      - postgres
      - mosquitto
      - redis
    environment:
      - MQTT_BROKER_HOST=mosquitto
      - REDIS_HOST=redis
      - POSTGRESQL_HOST=postgres
    ports:
      - 8080:8080
    ports:
      - 1700:1700/udp
    volumes:
    environment:
      - INTEGRATION__MQTT__EVENT_TOPIC_TEMPLATE=as923/gateway/{{ .GatewayID }}/event/{{ .EventType }}
      - INTEGRATION__MQTT__STATE_TOPIC_TEMPLATE=as923/gateway/{{ .GatewayID }}/state/{{ .StateType }}
      - INTEGRATION__MQTT__COMMAND_TOPIC_TEMPLATE=as923/gateway/{{ .GatewayID }}/command/#
    depends_on:
      - mosquitto
  chirpstack-gateway-bridge-basicstation:
    command: -c /etc/chirpstack-gateway-bridge/chirpstack-gateway-bridge-basicstation-as923.toml
    ports:
      - 3001:3001
    volumes:
    depends_on:
      - mosquitto
  chirpstack-rest-api:
    image: chirpstack/chirpstack-rest-api:4
    command: --server chirpstack:8080 --bind 0.0.0.0:8090 --insecure
    ports:
      - 8090:8090
    depends_on:
      - chirpstack
  postgres:
    image: postgres:14-alpine
    volumes:
    environment:
      - POSTGRES_PASSWORD=root
  redis:
    image: redis:7-alpine
    command: redis-server --save 300 1 --save 60 100 --appendonly no
    volumes:
      - redisdata:/data
  mosquitto:
    image: eclipse-mosquitto:2
    ports:
      - 1883:1883
    volumes:
      - ./configuration/mosquitto/config/:/mosquitto/config/
volumes:
  postgresqldata:
  redisdata:
Everything looks to be configured correctly, strange.
If you enter your mosquitto container and mosquitto_sub to the broker can you confirm the events being posted under the correct topic-prefix?
The MQTT connection is the only connection Chirpstack has to the gateways so if the topics are being posted correctly there Chirpstack should recognize that.
Im sorry but i am not quite sure how to enter to my mosquitto container and mosquitto_sub to the broker so that i can confirm the events being posted under the correct topic-prefix.
The answers are always just a google away :wink:
1. cd chirpstack-docker
2. sudo docker ps (then look for the name of your MQTT container, it is likely chirpstack-docker-mosquitto-1)
3. sudo docker exec -it chirpstack-docker-mosquitto-1 sh
4. mosquitto_sub -t "#" -v
Then look at the output and see what topic-prefix the events are being posted as.
thank you very much for the guidance. Somehow the topic is not changing to as923
Thank you so much for your help i have successfully change the region
