Admin login error
Hi all,
I started a fresh install with docker compose, chirpstack v4.0, running on Ubuntu 24.04 in a virtualized environment (distant server).
Everything gets up and running, but I cannot login using the default admin:admin credentials.
I found the following issue regarding avx support & virtualization;
From these posts, it seems regressing to Ubuntu server 20.04 solved the issue, but I cannot afford this. Is there any known issue that I might have overseen?
Cheers,
