Hello there, I try to use the api of version Chirpstack-4.7.0 but I fail.
I generate a token via web with API KEY.
Then with
curl -X 'GET' \
'https://console.helium-iot.xyz/api/applications/' \
-H 'accept: application/json' \
-H 'Grpc-Metadata-Authorization: TOKEN'
I get
"code": 16,
"message": "authorization metadata must in format 'Bearer <TOKEN>",
"details": []
I found this info, but I don’t understand it.
This seems better but how it’s applicable to chirpstack?
I found something good in forum this but still fails
curl -X 'GET' \
'https://console.helium-iot.xyz/api/applications' \
-H 'Grpc-Metadata-Authorization: Bearer <<TOKEN>>'
^^ Added Bearer, also '<<' before TOKEN and '>>' after token.
I get
{"code":16,"message":"Base64 error: Invalid byte 60, offset 0.","details":[]}
Without << >> but only with Bearer the error is
"code": 3,
"message": "invalid length: expected length 32 for simple format, found 0",
"details": []
