Hi Folks,
I’m trying to generate an API key that I can use with swagger for the REST API. I’ve tried creating one in the UI (as admin) and from the command line with
/opt/chirpstack/chirpstack --config /etc/chirpstack/chirpstack create-api-key --name cli
2024-02-07T13:17:05.377560Z INFO chirpstack::storage: Setting up PostgreSQL connection pool
2024-02-07T13:17:05.431838Z INFO chirpstack::storage: Applying schema migrations
2024-02-07T13:17:05.434539Z INFO chirpstack::storage: Setting up Redis client
2024-02-07T13:17:05.480258Z INFO chirpstack::storage::api_key: Api-key created id=3d30dcab-7df8-415a-8d19-d125738f7b76
token: eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJhdWQiOiJjaGlycHN0YWNrIiwiaXNzIjoiY2hpcnBzdGFjayIsInN1YiI6IjNkMzBkY2FiLTdkZjgtNDE1YS04ZDE5LWQxMjU3MzhmN2I3NiIsInR5cCI6ImtleSJ9.JHdw5SPCJJjvf4bcR6c93MamtRazuLGtJjgv9UtuRGU
However in both cases after then using the token in the Authorise section of the swagger and trying to do something like “GET /api/applications” gives:
401: authorization metadata must in format 'Bearer
