Hello
I´m tryng to configure ChirpStack Gateway OS on my raspberry 4 with RAK2245 gateway, but starting ChirpStack Concentratord I got the following message in sudo tail -f /var/log/messages |grep chirpstack-concentratord:
Mar 10 02:08:15 raspberrypi4 user.info monit[524]: ‘chirpstack-concentratord’ start: ‘/etc/init.d/chirpstack-concentratord start’
Mar 10 02:08:46 raspberrypi4 user.err monit[524]: ‘chirpstack-concentratord’ failed to start (exit status 1) – ‘/etc/init.d/chirpstack-concentratord start’: Configuration file does not exist
Mar 10 02:08:56 raspberrypi4 user.err monit[524]: ‘chirpstack-concentratord’ process is not running
Mar 10 02:08:56 raspberrypi4 user.info monit[524]: ‘chirpstack-concentratord’ trying to restart
Mar 10 02:08:56 raspberrypi4 user.info monit[524]: ‘chirpstack-concentratord’ start: ‘/etc/init.d/chirpstack-concentratord start’
Mar 10 02:09:26 raspberrypi4 user.err monit[524]: ‘chirpstack-concentratord’ failed to start (exit status 1) – ‘/etc/init.d/chirpstack-concentratord start’: Configuration file does not exist
Mar 10 02:09:36 raspberrypi4 user.err monit[524]: ‘chirpstack-concentratord’ process is not running
Mar 10 02:09:36 raspberrypi4 user.info monit[524]: ‘chirpstack-concentratord’ trying to restart
Mar 10 02:09:36 raspberrypi4 user.info monit[524]: ‘chirpstack-concentratord’ start: ‘/etc/init.d/chirpstack-concentratord start’
and showhig sudo monit status, I got this:
Process ‘chirpstack-concentratord’
status Initializing
monitoring status Initializing
monitoring mode active
on reboot start
data collected Sat, 10 Mar 2018 01:50:38
I don´t have idea where to fix this, please help.
warmest regards.
I’m having the same issue with RAK2287+ RAK 2003 pi hat version b on Raspberrypi3. Were you able to fix this?
Hello
The solution was change the ChirpStack Gateway OS version.
The version 4.1.0 give this problem, after I changed 4.0.0 version and works good! problem solve.
