@brocaar Thanks again for the help. I feel like I may be making progress, but Iâm not quite there yet.
I did the complete manual install described here: https://www.chirpstack.io/project/guides/debian-ubuntu/ including the ChirpStack Gateway Bridge, and the programs installed without complaint. I did the Postgresql setup and mosquitto install, and they load and run. Then I did the rak_common_for_gateway install, allowing it to bypass the ChirpStack installation.
Now when I start any of the ChirpStack programs or reboot, I get the following errors:
â Logs begin at Mon 2021-04-26 16:59:25 EDT. â
Apr 26 16:59:56 rak-gateway systemd[1]: Started ChirpStack Network Server.
Apr 26 16:59:56 rak-gateway systemd[1]: Started ChirpStack Application Server.
Apr 26 16:59:57 rak-gateway systemd[1]: Started ChirpStack Gateway Bridge.
Apr 26 16:59:57 rak-gateway systemd[1]: chirpstack-network-server.service: Main process exited, code=killed, status=4/ILL
Apr 26 16:59:57 rak-gateway systemd[1]: chirpstack-network-server.service: Failed with result âsignalâ.
Apr 26 16:59:57 rak-gateway systemd[1]: chirpstack-application-server.service: Main process exited, code=killed, status=4/ILL
Apr 26 16:59:57 rak-gateway systemd[1]: chirpstack-application-server.service: Failed with result âsignalâ.
Apr 26 16:59:57 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Main process exited, code=killed, status=4/ILL
Apr 26 16:59:57 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Failed with result âsignalâ.
Apr 26 16:59:58 rak-gateway systemd[1]: chirpstack-network-server.service: Service RestartSec=100ms expired, scheduling restart.
Apr 26 16:59:58 rak-gateway systemd[1]: chirpstack-network-server.service: Scheduled restart job, restart counter is at 1.
Apr 26 16:59:58 rak-gateway systemd[1]: chirpstack-application-server.service: Service RestartSec=100ms expired, scheduling restart.
Apr 26 16:59:58 rak-gateway systemd[1]: chirpstack-application-server.service: Scheduled restart job, restart counter is at 1.
Apr 26 16:59:58 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Service RestartSec=100ms expired, scheduling restart.
Apr 26 16:59:58 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Scheduled restart job, restart counter is at 1.
Apr 26 16:59:58 rak-gateway systemd[1]: Stopped ChirpStack Gateway Bridge.
Apr 26 16:59:58 rak-gateway systemd[1]: Started ChirpStack Gateway Bridge.
Apr 26 16:59:59 rak-gateway systemd[1]: Stopped ChirpStack Application Server.
Apr 26 16:59:59 rak-gateway systemd[1]: Started ChirpStack Application Server.
Apr 26 16:59:59 rak-gateway systemd[1]: Stopped ChirpStack Network Server.
Apr 26 16:59:59 rak-gateway systemd[1]: Started ChirpStack Network Server.
Apr 26 16:59:59 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Main process exited, code=killed, status=4/ILL
Apr 26 16:59:59 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Failed with result âsignalâ.
Apr 26 16:59:59 rak-gateway systemd[1]: chirpstack-application-server.service: Main process exited, code=killed, status=4/ILL
Apr 26 16:59:59 rak-gateway systemd[1]: chirpstack-application-server.service: Failed with result âsignalâ.
Apr 26 16:59:59 rak-gateway systemd[1]: chirpstack-network-server.service: Main process exited, code=killed, status=4/ILL
Apr 26 16:59:59 rak-gateway systemd[1]: chirpstack-network-server.service: Failed with result âsignalâ.
Apr 26 16:59:59 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Service RestartSec=100ms expired, scheduling restart.
Apr 26 16:59:59 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Scheduled restart job, restart counter is at 2.
Apr 26 16:59:59 rak-gateway systemd[1]: chirpstack-network-server.service: Service RestartSec=100ms expired, scheduling restart.
Apr 26 16:59:59 rak-gateway systemd[1]: chirpstack-network-server.service: Scheduled restart job, restart counter is at 2.
Apr 26 17:00:00 rak-gateway systemd[1]: chirpstack-application-server.service: Service RestartSec=100ms expired, scheduling restart.
Apr 26 17:00:00 rak-gateway systemd[1]: chirpstack-application-server.service: Scheduled restart job, restart counter is at 2.
Apr 26 17:00:00 rak-gateway systemd[1]: Stopped ChirpStack Application Server.
Apr 26 17:00:00 rak-gateway systemd[1]: Started ChirpStack Application Server.
Apr 26 17:00:00 rak-gateway systemd[1]: Stopped ChirpStack Network Server.
Apr 26 17:00:00 rak-gateway systemd[1]: Started ChirpStack Network Server.
Apr 26 17:00:00 rak-gateway systemd[1]: Stopped ChirpStack Gateway Bridge.
Apr 26 17:00:00 rak-gateway systemd[1]: Started ChirpStack Gateway Bridge.
Apr 26 17:00:00 rak-gateway systemd[1]: chirpstack-application-server.service: Main process exited, code=killed, status=4/ILL
Apr 26 17:00:00 rak-gateway systemd[1]: chirpstack-application-server.service: Failed with result âsignalâ.
Apr 26 17:00:00 rak-gateway systemd[1]: chirpstack-network-server.service: Main process exited, code=killed, status=4/ILL
Apr 26 17:00:00 rak-gateway systemd[1]: chirpstack-network-server.service: Failed with result âsignalâ.
Apr 26 17:00:00 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Main process exited, code=killed, status=4/ILL
Apr 26 17:00:00 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Failed with result âsignalâ.
Apr 26 17:00:00 rak-gateway systemd[1]: chirpstack-application-server.service: Scheduled restart job, restart counter is at 3.
Apr 26 17:00:01 rak-gateway systemd[1]: chirpstack-network-server.service: Service RestartSec=100ms expired, scheduling restart.
Apr 26 17:00:01 rak-gateway systemd[1]: chirpstack-network-server.service: Scheduled restart job, restart counter is at 3.
Apr 26 17:00:01 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Service RestartSec=100ms expired, scheduling restart.
Apr 26 17:00:01 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Scheduled restart job, restart counter is at 3.
Apr 26 17:00:01 rak-gateway systemd[1]: Stopped ChirpStack Gateway Bridge.
Apr 26 17:00:01 rak-gateway systemd[1]: Started ChirpStack Gateway Bridge.
Apr 26 17:00:01 rak-gateway systemd[1]: Stopped ChirpStack Network Server.
Apr 26 17:00:01 rak-gateway systemd[1]: Started ChirpStack Network Server.
Apr 26 17:00:01 rak-gateway systemd[1]: Stopped ChirpStack Application Server.
Apr 26 17:00:01 rak-gateway systemd[1]: Started ChirpStack Application Server.
Apr 26 17:00:01 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Main process exited, code=killed, status=4/ILL
Apr 26 17:00:01 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Failed with result âsignalâ.
Apr 26 17:00:01 rak-gateway systemd[1]: chirpstack-network-server.service: Main process exited, code=killed, status=4/ILL
Apr 26 17:00:01 rak-gateway systemd[1]: chirpstack-network-server.service: Failed with result âsignalâ.
Apr 26 17:00:01 rak-gateway systemd[1]: chirpstack-application-server.service: Main process exited, code=killed, status=4/ILL
Apr 26 17:00:01 rak-gateway systemd[1]: chirpstack-application-server.service: Failed with result âsignalâ.
Apr 26 17:00:01 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Scheduled restart job, restart counter is at 4.
Apr 26 17:00:01 rak-gateway systemd[1]: chirpstack-network-server.service: Scheduled restart job, restart counter is at 4.
Apr 26 17:00:01 rak-gateway systemd[1]: chirpstack-application-server.service: Service RestartSec=100ms expired, scheduling restart.
Apr 26 17:00:01 rak-gateway systemd[1]: chirpstack-application-server.service: Scheduled restart job, restart counter is at 4.
Apr 26 17:00:02 rak-gateway systemd[1]: Started ChirpStack Application Server.
Apr 26 17:00:02 rak-gateway systemd[1]: Stopped ChirpStack Network Server.
Apr 26 17:00:02 rak-gateway systemd[1]: Started ChirpStack Network Server.
Apr 26 17:00:02 rak-gateway systemd[1]: chirpstack-application-server.service: Main process exited, code=killed, status=4/ILL
Apr 26 17:00:02 rak-gateway systemd[1]: chirpstack-application-server.service: Failed with result âsignalâ.
Apr 26 17:00:02 rak-gateway systemd[1]: chirpstack-network-server.service: Main process exited, code=killed, status=4/ILL
Apr 26 17:00:02 rak-gateway systemd[1]: chirpstack-network-server.service: Failed with result âsignalâ.
Apr 26 17:00:02 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Service RestartSec=100ms expired, scheduling restart.
Apr 26 17:00:02 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Scheduled restart job, restart counter is at 5.
Apr 26 17:00:02 rak-gateway systemd[1]: Stopped ChirpStack Gateway Bridge.
Apr 26 17:00:02 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Start request repeated too quickly.
Apr 26 17:00:02 rak-gateway systemd[1]: chirpstack-gateway-bridge.service: Failed with result âsignalâ.
Apr 26 17:00:02 rak-gateway systemd[1]: Failed to start ChirpStack Gateway Bridge.
Apr 26 17:00:02 rak-gateway systemd[1]: chirpstack-application-server.service: Service RestartSec=100ms expired, scheduling restart.
Apr 26 17:00:02 rak-gateway systemd[1]: chirpstack-application-server.service: Scheduled restart job, restart counter is at 5.
Apr 26 17:00:02 rak-gateway systemd[1]: chirpstack-network-server.service: Service RestartSec=100ms expired, scheduling restart.
Apr 26 17:00:02 rak-gateway systemd[1]: chirpstack-network-server.service: Scheduled restart job, restart counter is at 5.
Apr 26 17:00:02 rak-gateway systemd[1]: chirpstack-network-server.service: Start request repeated too quickly.
Apr 26 17:00:02 rak-gateway systemd[1]: Failed to start ChirpStack Network Server.
Apr 26 17:00:02 rak-gateway systemd[1]: Stopped ChirpStack Application Server.
Apr 26 17:00:02 rak-gateway systemd[1]: chirpstack-application-server.service: Start request repeated too quickly.
Apr 26 17:00:02 rak-gateway systemd[1]: Failed to start ChirpStack Application Server.
What do I need to do next?
