Hi , I have made a set up wit a Pi 3 with a IC880A and installed the Chirpstack software , after I set up the concentrator (I only had to give the position of the rest GPIO) I’am trying to follow the installation guide from Mobilefish but need My gateway ID for config. anybody knows where i can find it on the linux terminal? Thanks in advance
BTW: fuld image chirpstack server used.
If you are using the ChirpStack Gateway OS, you can run sudo gateway-id
