vg000n
1
Hi.
I’m trying to repurpose a Sensecap M1 Lora Gateway from Seeedstudio as a Chirpstack Full instance.
While I’m, trying my best to set everything up, I’m failing in findindig how to discover the Gateway ID (EUI64) of the Gateway
if I run (as I read here - post is 5 years ago)
sudo gateway-id
I receive
could not read gateway_id
What do you mean by this, did you install Chirpstack Gateway OS Full Image onto the Sensecap, or are you trying a different installation?
vg000n
3
I have installed it and I’m living the dream lol
If you go to the Chirpstack concentratord tab and look in the bottom right corner, does it show your gateway ID like in the photo here:
https://www.chirpstack.io/docs/chirpstack-gateway-os/index.html
vg000n
5
Wow.
will check as soon as I’m back to the office.
Thanks in advance
vg000n
6
Thanks it worked.
I had to enable it it was somehow not eanbled.
thanks
