My Error looks the same like the Error from overdull.
raspberrypi:~$ /usr/bin/chirpstack-concentratord-sx1301 -c /etc/chirpstack-concentratord/sx1301/global.toml -c /etc/chirpstack-concentratord/sx1301/band.toml -c /etc/chirpstack-concentratord/sx1301/channels.toml
2020-03-25 10:06:37,655 INFO [chirpstack_concentratord_sx1301::cmd::root] Starting Concentratord SX1301 (version: 3.0.0-test.5, docs: https://www.chirpstack.io/concentratord/)
2020-03-25 10:06:37,659 INFO [chirpstack_concentratord_sx1301::concentrator] Setting spi device path, spidev_path: /dev/spidev0.0
2020-03-25 10:06:37,662 INFO [chirpstack_concentratord_sx1301::concentrator] Setting board configuration, lorawan_public: true, clock_source: 1
2020-03-25 10:06:37,662 INFO [chirpstack_concentratord_sx1301::concentrator] Setting up concentrator radios
2020-03-25 10:06:37,664 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257
2020-03-25 10:06:37,665 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257
2020-03-25 10:06:37,666 INFO [chirpstack_concentratord_sx1301::concentrator] Setting up concentrator channels
2020-03-25 10:06:37,667 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000
2020-03-25 10:06:37,669 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
2020-03-25 10:06:37,669 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0
2020-03-25 10:06:37,672 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000
2020-03-25 10:06:37,678 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000
2020-03-25 10:06:37,680 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0
2020-03-25 10:06:37,681 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000
2020-03-25 10:06:37,682 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000
2020-03-25 10:06:37,683 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
2020-03-25 10:06:37,684 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
2020-03-25 10:06:37,687 INFO [chirpstack_concentratord_sx1301::concentrator] Starting the the concentrator
thread 'main' panicked at 'called `Result::unwrap()` on an `Err` value: "lgw_start failed"', src/libcore/result.rs:1188:5
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace.
The reset script is using the content from the environment variable "$CONCENTRATOR_RESET_PIN". But where is it set?
If i switche to root with sudo su and run the command, than i get exactly the same error message.
raspberrypi:/home/admin# /usr/bin/chirpstack-concentratord-sx1301 -c /etc/chirpstack-concentratord/sx1301/global.toml -c /etc/chirpstack-concentratord/sx1301/band.toml -c /etc/chirpstack-concentratord/sx1301/channels.toml
2020-03-25 10:16:29,857 INFO [chirpstack_concentratord_sx1301::cmd::root] Starting Concentratord SX1301 (version: 3.0.0-test.5, docs: https://www.chirpstack.io/concentratord/)
2020-03-25 10:16:29,860 INFO [chirpstack_concentratord_sx1301::concentrator] Setting spi device path, spidev_path: /dev/spidev0.0
2020-03-25 10:16:29,863 INFO [chirpstack_concentratord_sx1301::concentrator] Setting board configuration, lorawan_public: true, clock_source: 1
2020-03-25 10:16:29,865 INFO [chirpstack_concentratord_sx1301::concentrator] Setting up concentrator radios
2020-03-25 10:16:29,866 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257
2020-03-25 10:16:29,867 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257
2020-03-25 10:16:29,869 INFO [chirpstack_concentratord_sx1301::concentrator] Setting up concentrator channels
2020-03-25 10:16:29,870 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000
2020-03-25 10:16:29,873 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
2020-03-25 10:16:29,874 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0
2020-03-25 10:16:29,875 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000
2020-03-25 10:16:29,876 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000
2020-03-25 10:16:29,878 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0
2020-03-25 10:16:29,879 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000
2020-03-25 10:16:29,881 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000
2020-03-25 10:16:29,882 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
2020-03-25 10:16:29,882 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
2020-03-25 10:16:29,884 INFO [chirpstack_concentratord_sx1301::concentrator] Starting the the concentrator
ERROR: Failed to load fw 1
ERROR: Version of calibration firmware not expected, actual:0 expected:2
