Hi folks,
i’m trying to integrate influxDB 2.0, below the configuration that I made:
I cannot see anything in influxDB nor in application server logs, in application server logs I cannot see any call for the influxDB API.
Please note that my chirpstack is installed with docker image and influxDB 2.0 is installed in the host machine, and I can see the uplink data decoded in Device data tab
fmgst
September 24, 2021, 7:08pm
#2
Did you see this thread?
There, @brocaar suggested “Have you checked the ChirpStack Application Server and / or InfluxDB server logs? That is usually a good start to troubleshoot issues” - did you do that? I think without someone doing that & then posting results to that thread, there isn’t enough to go on or even to determine where the problem is (chirpstack, integration, or InfluxDB).
I don’t use (or know anything about) InfluxDB. That said, I did find a video showing how to integrate V1.7xx InfluxDB with loraserver (which is what ChirpStack used to be called prior to November 2019 ). Can you see if those steps still work?
I followed the same video Setup Loraserver [4] - Get data with InfluxDB Integration - YouTube and I did some adaptation.
For the logs, the problem nothing is coming in the logs of the application server seems not reading the configuration!!!
Below some logs of my application-server, you can see that nothing related to POST for influxDB:
time=“2021-09-21T14:32:59.8631286Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=423eed3d-7251-45bb-a8ad-715f01dbb9d7 name=“gw:GW-ID”
time=“2021-09-21T14:32:59.8631903Z” level=info msg=“finished unary call with code OK” ctx_id=423eed3d-7251-45bb-a8ad-715f01dbb9d7 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:32:59Z” grpc.time_ms=8.516 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:33:19.8703761Z” level=info msg=“gateway updated” ctx_id=4890297f-b658-4fa8-b105-d2a04b642558 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:33:19.8731938Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=4890297f-b658-4fa8-b105-d2a04b642558 name=“gw:GW-ID”
time=“2021-09-21T14:33:19.8732888Z” level=info msg=“finished unary call with code OK” ctx_id=4890297f-b658-4fa8-b105-d2a04b642558 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:33:19Z” grpc.time_ms=5.155 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:33:39.8816309Z” level=info msg=“gateway updated” ctx_id=7a5ffa29-825e-4992-8735-0c25db8edbcc id=GW-ID name=MT-Multitech
time=“2021-09-21T14:33:39.8898317Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=7a5ffa29-825e-4992-8735-0c25db8edbcc name=“gw:GW-ID”
time=“2021-09-21T14:33:39.8899326Z” level=info msg=“finished unary call with code OK” ctx_id=7a5ffa29-825e-4992-8735-0c25db8edbcc grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:33:39Z” grpc.time_ms=10.809 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:33:59.8616366Z” level=info msg=“gateway updated” ctx_id=6585886b-a4d7-4cf4-a516-5527b5b9f147 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:33:59.8731473Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=6585886b-a4d7-4cf4-a516-5527b5b9f147 name=“gw:GW-ID”
time=“2021-09-21T14:33:59.8733103Z” level=info msg=“finished unary call with code OK” ctx_id=6585886b-a4d7-4cf4-a516-5527b5b9f147 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:33:59Z” grpc.time_ms=14.79 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:34:19.8672197Z” level=info msg=“gateway updated” ctx_id=adef9094-60f8-4977-bd8d-5c08a2999a0b id=GW-ID name=MT-Multitech
time=“2021-09-21T14:34:19.8793787Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=adef9094-60f8-4977-bd8d-5c08a2999a0b name=“gw:GW-ID”
time=“2021-09-21T14:34:19.8794865Z” level=info msg=“finished unary call with code OK” ctx_id=adef9094-60f8-4977-bd8d-5c08a2999a0b grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:34:19Z” grpc.time_ms=13.889 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:34:39.982393Z” level=info msg=“gateway updated” ctx_id=69942ffe-eec5-4ed9-bddc-2c62c42c56ea id=GW-ID name=MT-Multitech
time=“2021-09-21T14:34:39.9884685Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=69942ffe-eec5-4ed9-bddc-2c62c42c56ea name=“gw:GW-ID”
time=“2021-09-21T14:34:39.988524Z” level=info msg=“finished unary call with code OK” ctx_id=69942ffe-eec5-4ed9-bddc-2c62c42c56ea grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:34:39Z” grpc.time_ms=9.397 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:34:59.8744995Z” level=info msg=“gateway updated” ctx_id=568e521e-8b37-48b5-a6a8-7a1c49c1f69a id=GW-ID name=MT-Multitech
time=“2021-09-21T14:34:59.8889565Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=568e521e-8b37-48b5-a6a8-7a1c49c1f69a name=“gw:GW-ID”
time=“2021-09-21T14:34:59.8890223Z” level=info msg=“finished unary call with code OK” ctx_id=568e521e-8b37-48b5-a6a8-7a1c49c1f69a grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:34:59Z” grpc.time_ms=17.156 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:35:19.8953734Z” level=info msg=“gateway updated” ctx_id=87a92530-59d6-474f-bab0-72fbda6e89f4 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:35:19.9212919Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=87a92530-59d6-474f-bab0-72fbda6e89f4 name=“gw:GW-ID”
time=“2021-09-21T14:35:19.9213535Z” level=info msg=“finished unary call with code OK” ctx_id=87a92530-59d6-474f-bab0-72fbda6e89f4 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:35:19Z” grpc.time_ms=28.674 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:35:39.8902823Z” level=info msg=“gateway updated” ctx_id=796451ef-783b-4e55-aa57-f802f58c8bf8 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:35:39.8959919Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=796451ef-783b-4e55-aa57-f802f58c8bf8 name=“gw:GW-ID”
time=“2021-09-21T14:35:39.8960628Z” level=info msg=“finished unary call with code OK” ctx_id=796451ef-783b-4e55-aa57-f802f58c8bf8 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:35:39Z” grpc.time_ms=7.11 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:35:59.9099233Z” level=info msg=“gateway updated” ctx_id=6d9049d3-34e7-4036-b50e-ff2e7ce06b68 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:35:59.9238628Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=6d9049d3-34e7-4036-b50e-ff2e7ce06b68 name=“gw:GW-ID”
time=“2021-09-21T14:35:59.9241345Z” level=info msg=“finished unary call with code OK” ctx_id=6d9049d3-34e7-4036-b50e-ff2e7ce06b68 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:35:59Z” grpc.time_ms=16.197 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:36:19.9318705Z” level=info msg=“gateway updated” ctx_id=1df0de12-f262-467a-902d-1012ca8bee7b id=GW-ID name=MT-Multitech
time=“2021-09-21T14:36:19.9883586Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=1df0de12-f262-467a-902d-1012ca8bee7b name=“gw:GW-ID”
time=“2021-09-21T14:36:19.9884216Z” level=info msg=“finished unary call with code OK” ctx_id=1df0de12-f262-467a-902d-1012ca8bee7b grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:36:19Z” grpc.time_ms=67.619 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:36:39.8945104Z” level=info msg=“gateway updated” ctx_id=ecc37b1f-8e43-441a-ba40-14e97838575d id=GW-ID name=MT-Multitech
time=“2021-09-21T14:36:39.8978355Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=ecc37b1f-8e43-441a-ba40-14e97838575d name=“gw:GW-ID”
time=“2021-09-21T14:36:39.8978881Z” level=info msg=“finished unary call with code OK” ctx_id=ecc37b1f-8e43-441a-ba40-14e97838575d grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:36:39Z” grpc.time_ms=6.748 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:36:59.8919543Z” level=info msg=“gateway updated” ctx_id=09cc3089-9dbf-40b4-a397-8b4eee262a67 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:36:59.8950218Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=09cc3089-9dbf-40b4-a397-8b4eee262a67 name=“gw:GW-ID”
time=“2021-09-21T14:36:59.8950707Z” level=info msg=“finished unary call with code OK” ctx_id=09cc3089-9dbf-40b4-a397-8b4eee262a67 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:36:59Z” grpc.time_ms=9.029 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:37:19.9138079Z” level=info msg=“gateway updated” ctx_id=e26ce226-0229-4097-93f2-166e25fd07f9 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:37:19.9177018Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=e26ce226-0229-4097-93f2-166e25fd07f9 name=“gw:GW-ID”
time=“2021-09-21T14:37:19.9177603Z” level=info msg=“finished unary call with code OK” ctx_id=e26ce226-0229-4097-93f2-166e25fd07f9 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:37:19Z” grpc.time_ms=12.245 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:37:39.8986574Z” level=info msg=“gateway updated” ctx_id=e73aac75-20ad-4fea-8d98-2e674abaa6b2 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:37:39.9051192Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=e73aac75-20ad-4fea-8d98-2e674abaa6b2 name=“gw:GW-ID”
time=“2021-09-21T14:37:39.9051722Z” level=info msg=“finished unary call with code OK” ctx_id=e73aac75-20ad-4fea-8d98-2e674abaa6b2 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:37:39Z” grpc.time_ms=9.543 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:37:59.8951645Z” level=info msg=“gateway updated” ctx_id=ebcfd799-4b5e-475f-ae18-74b2ee0f389b id=GW-ID name=MT-Multitech
time=“2021-09-21T14:37:59.9009243Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=ebcfd799-4b5e-475f-ae18-74b2ee0f389b name=“gw:GW-ID”
time=“2021-09-21T14:37:59.9009859Z” level=info msg=“finished unary call with code OK” ctx_id=ebcfd799-4b5e-475f-ae18-74b2ee0f389b grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:37:59Z” grpc.time_ms=10.101 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:38:19.9072444Z” level=info msg=“gateway updated” ctx_id=f6204a4d-ba73-4bae-b5eb-a5cc213f0ca7 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:38:19.9125294Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=f6204a4d-ba73-4bae-b5eb-a5cc213f0ca7 name=“gw:GW-ID”
time=“2021-09-21T14:38:19.912577Z” level=info msg=“finished unary call with code OK” ctx_id=f6204a4d-ba73-4bae-b5eb-a5cc213f0ca7 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:38:19Z” grpc.time_ms=9.924 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:38:39.9080497Z” level=info msg=“gateway updated” ctx_id=e41ce53a-ce6e-48f9-929f-6eaee2d04159 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:38:39.9233182Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=e41ce53a-ce6e-48f9-929f-6eaee2d04159 name=“gw:GW-ID”
time=“2021-09-21T14:38:39.9233922Z” level=info msg=“finished unary call with code OK” ctx_id=e41ce53a-ce6e-48f9-929f-6eaee2d04159 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:38:39Z” grpc.time_ms=17.453 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:38:59.9059179Z” level=info msg=“gateway updated” ctx_id=7acff101-7bd4-43db-9a03-f50d2b6159cf id=GW-ID name=MT-Multitech
time=“2021-09-21T14:38:59.9093269Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=7acff101-7bd4-43db-9a03-f50d2b6159cf name=“gw:GW-ID”
time=“2021-09-21T14:38:59.9093844Z” level=info msg=“finished unary call with code OK” ctx_id=7acff101-7bd4-43db-9a03-f50d2b6159cf grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:38:59Z” grpc.time_ms=9.897 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:39:19.8939617Z” level=info msg=“gateway updated” ctx_id=c7a9a3e9-928d-4b69-8f67-5116cf45421b id=GW-ID name=MT-Multitech
time=“2021-09-21T14:39:19.8963617Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=c7a9a3e9-928d-4b69-8f67-5116cf45421b name=“gw:GW-ID”
time=“2021-09-21T14:39:19.8964099Z” level=info msg=“finished unary call with code OK” ctx_id=c7a9a3e9-928d-4b69-8f67-5116cf45421b grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:39:19Z” grpc.time_ms=11.971 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:39:39.9067838Z” level=info msg=“gateway updated” ctx_id=558b54b4-dd64-4c8c-827a-62336567e2ad id=GW-ID name=MT-Multitech
time=“2021-09-21T14:39:39.91125Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=558b54b4-dd64-4c8c-827a-62336567e2ad name=“gw:GW-ID”
time=“2021-09-21T14:39:39.9113116Z” level=info msg=“finished unary call with code OK” ctx_id=558b54b4-dd64-4c8c-827a-62336567e2ad grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:39:39Z” grpc.time_ms=7.232 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:39:59.903211Z” level=info msg=“gateway updated” ctx_id=acd31469-e632-45dc-a403-7c3ab5b3fa56 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:39:59.9072564Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=acd31469-e632-45dc-a403-7c3ab5b3fa56 name=“gw:GW-ID”
time=“2021-09-21T14:39:59.907345Z” level=info msg=“finished unary call with code OK” ctx_id=acd31469-e632-45dc-a403-7c3ab5b3fa56 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:39:59Z” grpc.time_ms=12.371 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:40:19.9119832Z” level=info msg=“gateway updated” ctx_id=68113e2c-c7be-442e-9da8-4f8351fc767e id=GW-ID name=MT-Multitech
time=“2021-09-21T14:40:19.9151071Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=68113e2c-c7be-442e-9da8-4f8351fc767e name=“gw:GW-ID”
time=“2021-09-21T14:40:19.9151599Z” level=info msg=“finished unary call with code OK” ctx_id=68113e2c-c7be-442e-9da8-4f8351fc767e grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:40:19Z” grpc.time_ms=8.395 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:40:39.910316Z” level=info msg=“gateway updated” ctx_id=f564acf8-b96d-423f-83bf-3fb6a9b8e585 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:40:39.9152658Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=f564acf8-b96d-423f-83bf-3fb6a9b8e585 name=“gw:GW-ID”
time=“2021-09-21T14:40:39.9153433Z” level=info msg=“finished unary call with code OK” ctx_id=f564acf8-b96d-423f-83bf-3fb6a9b8e585 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:40:39Z” grpc.time_ms=8.229 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:40:59.9318788Z” level=info msg=“gateway updated” ctx_id=e2855bce-0171-4b20-8fcd-b3040fa610b7 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:40:59.9359534Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=e2855bce-0171-4b20-8fcd-b3040fa610b7 name=“gw:GW-ID”
time=“2021-09-21T14:40:59.9360047Z” level=info msg=“finished unary call with code OK” ctx_id=e2855bce-0171-4b20-8fcd-b3040fa610b7 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:40:59Z” grpc.time_ms=9.737 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:41:19.9228249Z” level=info msg=“gateway updated” ctx_id=bff93c96-fc53-4c6a-ba69-abfa9c116b83 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:41:19.930803Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=bff93c96-fc53-4c6a-ba69-abfa9c116b83 name=“gw:GW-ID”
time=“2021-09-21T14:41:19.9308604Z” level=info msg=“finished unary call with code OK” ctx_id=bff93c96-fc53-4c6a-ba69-abfa9c116b83 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:41:19Z” grpc.time_ms=12.083 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:41:39.9198596Z” level=info msg=“gateway updated” ctx_id=16374f5b-3a42-477a-add6-21dbcf5061c9 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:41:39.9239841Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=16374f5b-3a42-477a-add6-21dbcf5061c9 name=“gw:GW-ID”
time=“2021-09-21T14:41:39.9240685Z” level=info msg=“finished unary call with code OK” ctx_id=16374f5b-3a42-477a-add6-21dbcf5061c9 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:41:39Z” grpc.time_ms=13.299 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:41:59.9250957Z” level=info msg=“gateway updated” ctx_id=53858761-42d5-4793-bdc2-327202480160 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:41:59.9361673Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=53858761-42d5-4793-bdc2-327202480160 name=“gw:GW-ID”
time=“2021-09-21T14:41:59.9362302Z” level=info msg=“finished unary call with code OK” ctx_id=53858761-42d5-4793-bdc2-327202480160 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:41:59Z” grpc.time_ms=14.283 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:42:19.9055124Z” level=info msg=“gateway updated” ctx_id=d79bed8b-3ec5-4b86-8860-588b4e2227d8 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:42:19.9088634Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=d79bed8b-3ec5-4b86-8860-588b4e2227d8 name=“gw:GW-ID”
time=“2021-09-21T14:42:19.9089515Z” level=info msg=“finished unary call with code OK” ctx_id=d79bed8b-3ec5-4b86-8860-588b4e2227d8 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:42:19Z” grpc.time_ms=5.511 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:42:39.907895Z” level=info msg=“gateway updated” ctx_id=4a6348c3-8ff8-4321-8545-c313e030e3be id=GW-ID name=MT-Multitech
time=“2021-09-21T14:42:39.9126137Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=4a6348c3-8ff8-4321-8545-c313e030e3be name=“gw:GW-ID”
time=“2021-09-21T14:42:39.9126795Z” level=info msg=“finished unary call with code OK” ctx_id=4a6348c3-8ff8-4321-8545-c313e030e3be grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:42:39Z” grpc.time_ms=6.871 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:42:59.9394305Z” level=info msg=“gateway updated” ctx_id=4a47efc1-fe0d-4d06-822c-eea3fb6eb2f1 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:42:59.9443838Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=4a47efc1-fe0d-4d06-822c-eea3fb6eb2f1 name=“gw:GW-ID”
time=“2021-09-21T14:42:59.9444654Z” level=info msg=“finished unary call with code OK” ctx_id=4a47efc1-fe0d-4d06-822c-eea3fb6eb2f1 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:42:59Z” grpc.time_ms=10.682 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:43:19.9184818Z” level=info msg=“gateway updated” ctx_id=00b4c0a6-d59d-4dbf-a4f2-55f51357cc18 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:43:19.9221588Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=00b4c0a6-d59d-4dbf-a4f2-55f51357cc18 name=“gw:GW-ID”
time=“2021-09-21T14:43:19.9222282Z” level=info msg=“finished unary call with code OK” ctx_id=00b4c0a6-d59d-4dbf-a4f2-55f51357cc18 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:43:19Z” grpc.time_ms=7.789 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:43:39.9176707Z” level=info msg=“gateway updated” ctx_id=901c4cb9-a329-497a-8b99-bf681228a963 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:43:39.9217943Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=901c4cb9-a329-497a-8b99-bf681228a963 name=“gw:GW-ID”
time=“2021-09-21T14:43:39.9218563Z” level=info msg=“finished unary call with code OK” ctx_id=901c4cb9-a329-497a-8b99-bf681228a963 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:43:39Z” grpc.time_ms=7.537 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:43:59.9188155Z” level=info msg=“gateway updated” ctx_id=73220602-6068-4e3d-a86f-5cfee13cd89a id=GW-ID name=MT-Multitech
time=“2021-09-21T14:43:59.9338673Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=73220602-6068-4e3d-a86f-5cfee13cd89a name=“gw:GW-ID”
time=“2021-09-21T14:43:59.935178Z” level=info msg=“finished unary call with code OK” ctx_id=73220602-6068-4e3d-a86f-5cfee13cd89a grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:43:59Z” grpc.time_ms=24.218 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:44:19.9164086Z” level=info msg=“gateway updated” ctx_id=6e75ea4c-40de-4aa9-912e-934a79f0a2ff id=GW-ID name=MT-Multitech
time=“2021-09-21T14:44:19.9195109Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=6e75ea4c-40de-4aa9-912e-934a79f0a2ff name=“gw:GW-ID”
time=“2021-09-21T14:44:19.9195998Z” level=info msg=“finished unary call with code OK” ctx_id=6e75ea4c-40de-4aa9-912e-934a79f0a2ff grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:44:19Z” grpc.time_ms=6.893 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:44:39.9308288Z” level=info msg=“gateway updated” ctx_id=d517b371-21da-4855-a47a-154439e92fe2 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:44:39.9359467Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=d517b371-21da-4855-a47a-154439e92fe2 name=“gw:GW-ID”
time=“2021-09-21T14:44:39.9360034Z” level=info msg=“finished unary call with code OK” ctx_id=d517b371-21da-4855-a47a-154439e92fe2 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:44:39Z” grpc.time_ms=17.674 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:44:59.9339609Z” level=info msg=“gateway updated” ctx_id=79ee2fc0-dab0-4e57-a04d-8508843de753 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:44:59.9375709Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=79ee2fc0-dab0-4e57-a04d-8508843de753 name=“gw:GW-ID”
time=“2021-09-21T14:44:59.9376854Z” level=info msg=“finished unary call with code OK” ctx_id=79ee2fc0-dab0-4e57-a04d-8508843de753 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:44:59Z” grpc.time_ms=12.122 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:45:19.9336596Z” level=info msg=“gateway updated” ctx_id=e2670379-a36e-4f69-9dc8-8cd72b01b839 id=GW-ID name=MT-Multitech
time=“2021-09-21T14:45:19.9393687Z” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=e2670379-a36e-4f69-9dc8-8cd72b01b839 name=“gw:GW-ID”
time=“2021-09-21T14:45:19.9394289Z” level=info msg=“finished unary call with code OK” ctx_id=e2670379-a36e-4f69-9dc8-8cd72b01b839 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2021-09-21T14:45:19Z” grpc.time_ms=9.908 peer.address=“172.19.0.5:57860” span.kind=server system=grpc
time=“2021-09-21T14:45:39.9256797Z” level=info msg=“gateway updated” ctx_id=ce138d78-5326-4800-8cb0-b5686f9d384c id=GW-ID name=MT-Multitech
Hi folks,
After installation of influxDB 2.0.8, application server can send POST request to the influxDB but I have the below issue (seems that token need to be mentioned in the application server, but no option in the current GUI)
@orne your support please.
Issue was resolved, we just to install the master branch of chirpstack-docker
