SSH OK:
1.) Ubuntu commandline SSH
2.) Putty (even with Wine on Ubuntu)
SSH NOK:
1.) However, if I use other clients, like FileZilla with sftp, I get the following error in FileZilla:
Connect with 10.0.1.121…
fzSftp started, protocol_version=8
open “admin@10.0.1.121” 22
Pass: *****
Connected to 10.0.1.121
Received unexpected end-of-file from SFTP server
2.) Normally I use Ubuntu PAC as a SSH connection manager. This does not work either with the dropbear implementation of ChirpStack OS:
PAC Log:
CONNECTING WITH ‘Gateways - LoRaGateway-01’ (Thu Jul 23 14:00:23 2020) =->
<-= DISCONNECTED (PRESS TO RECONNECT) (Thu Jul 23 14:00:24 2020)
Dropbear log:
Jul 23 12:00:24 raspberrypi4 authpriv.info dropbear[6717]: Child connection from 10.0.1.135:40358
Jul 23 12:00:24 raspberrypi4 authpriv.info dropbear[6717]: Exit before auth: Exited normally
Jul 23 12:00:26 raspberrypi4 auth.err getty[6736]: tcgetattr: Input/output error^M
I use the latest ChirpStack OS:
https://artifacts.chirpstack.io/downloads/chirpstack-gateway-os/raspberrypi/raspberrypi4/3.3.0-test.7/chirpstack-gateway-os-full-raspberrypi4-20200720152644.rootfs.wic.gz
