Hi @brocaar and everyone,
I tried to create a gRPC client using node.js but I always get this error
E1213 18:51:21.178556268 7608 ssl_transport_security.c:970] Handshake failed with fatal error SSL_ERROR_SSL: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed.
Error: Connect Failed
at /home/dycode/git/nonwork/playground/loraserver_grpc/node_modules/grpc/src/client.js:554:15
I might miss a configuration, beause I’m using the same SSL certificate and private key with the
LoRa app server.
Here’s the node.js code:
'use strict';
const path = require(`path`);
const grpc = require(`grpc`);
const Promise = require(`bluebird`);
const config = require(`./config`);
const fs = require(`fs`);
const PROTO_PATH = path.join(__dirname, `./proto/application.proto`);
const { api } = grpc.load(PROTO_PATH);
const creds = {
privkey: fs.readFileSync(path.join(__dirname, `ssl/privkey`)),
cert: fs.readFileSync(path.join(__dirname, `ssl/certificate`)),
async function main() {
const { Application } = api;
const client = Promise.promisifyAll(
new Application(
`${config.server.hostname}:${config.server.port}`,
grpc.credentials.createSsl(null, creds.privkey, creds.cert)
const res = await client.listAsync({ limit: 10, offset: 0 });
console.log(res);
main()
.catch((ex) => {
console.error(ex.stack);
And here’s the docker-compose.yml file
version: "2"
services:
loraserver:
image: loraserver/loraserver
ports:
- 8000:8000
environment:
- DB_AUTOMIGRATE=true
- LOG_NODE_FRAMES=true
- NET_ID=010203
- BAND=AS_923
- REDIS_URL=redis://redis:6379
- GW_MQTT_SERVER=tcp://mosquitto:1883
- GW_SERVER_JWT_SECRET=verysecret
- POSTGRES_DSN=postgres://loraserver_ns:loraserver_ns@postgresql_ns/loraserver_ns?sslmode=disable
- JS_SERVER=http://appserver:8003
appserver:
image: loraserver/lora-app-server
volumes:
- ./ssl:/ssl
ports:
- 8080:8080
environment:
- POSTGRES_DSN=postgres://loraserver_as:loraserver_as@postgresql_as?sslmode=disable
- MQTT_SERVER=tcp://mosquitto:1883
- JWT_SECRET=verysecret
- HTTP_TLS_CERT=/ssl/certificate
- HTTP_TLS_KEY=/ssl/privkey
- AS_PUBLIC_SERVER=appserver:8001
- TLS_CERT=/ssl/certificate
- TLS_KEY=/ssl/privkey
gatewaybridge:
ports:
- 1700:1700/udp
image: loraserver/lora-gateway-bridge
environment:
postgresql_ns:
image: postgres:9.6-alpine
volumes:
- ./postgresql_ns_data:/var/lib/postgresql/data
ports:
- 5432
environment:
- POSTGRES_PASSWORD=loraserver_ns
- POSTGRES_USER=loraserver_ns
- POSTGRES_DB=loraserver_ns
postgresql_as:
volumes:
- ./postgresql_as_data:/var/lib/postgresql/data
ports:
- 5432
environment:
- POSTGRES_PASSWORD=loraserver_as
- POSTGRES_USER=loraserver_as
- POSTGRES_DB=loraserver_as
redis:
volumes:
- ./redis_data:/data
image: redis:4-alpine
ports:
- 6379
mosquitto:
image: eclipse-mosquitto
ports:
- 1883:1883
