I was trying to give the Gateway OS a Static IP, and as per the rules I edited the “interfaces file”
under /etc/network
as follows:
#Wired or wireless interfaces
auto eth0
iface eth0 inet static
address 192.168.1.2
netmask 255.255.255.0
network 192.168.1.0
gateway 192.168.1.1
After rebooting the Gateway OS, I was able to see through ifconfig
that the Static IP was allotted to it. But as soon as I accessed the Chirpstack Application Serve
r through localhost:8080
, and clicked on any registered Application
, it showed the following error:
redis connection error: dial tcp [::1]:6379: connect: connection refused (code: 2)
Now, if I allot the same Static IP as above but keep the netmask
and the gateway
as default i.e. :-
auto eth0
address 192.168.1.2
network 192.168.7.0
gateway 192.168.7.1
and reboot the gateway, it still gets the Static IP as shown by the ifconfig
command, and I am able to also access the Chirpstack Application Server
without any error by the Redis
But as can been seen, as the IP address
belongs to the Class C network
; the first three bytes, 192.168.1 forms the network
. The final byte in this example, 2, is the host
So the network
and gateway
IP’s should fall within the network.
Therefore the configurations provided in the latter case should be technically wrong, and the former configurations should be correct.
But the chirpstack application server
cannot connect to Redis
on the former Static IP Configurations.
Also, I cannot change the redis bind address
to 0.0.0.0
in /etc/redis/redis.conf
as that is not a solution to this problem and anyone can connect to this Redis
instance, which is highly insecure.
It would be great if someone could solve my problem!
Thank you so much!
