This makes it possible to generate (and revoke) API keys directly from within
the web-interface. Internally, a lot of authorization code has been cleaned up
to remove duplication and make the code easier to maintain. (#421)
Improvements
Use server time instead of gateway reported time in stats. (#440)
Bugfixes
Fix objectJSON formatting in web-interface.
Fix AMQP re-connect issue.
Fix setting updated_at field on organization user update. (#430)
Fix create service-profile with empty name. (#436)
Testing
Debian
Use the testing channel instead of stable:
sudo echo "deb https://artifacts.chirpstack.io/packages/3.x/deb testing main" | sudo tee /etc/apt/sources.list.d/chirpstack.list
Docker
Use the chirpstack/chirpstack-application-server:3.10.0-test.1 image and tag (will be available shortly).
This makes it possible to generate (and revoke) API keys directly from within the web-interface. Internally, a lot of authorization code has been cleaned up to remove duplication and make the code easier to maintain. (#421)
