[release] ChirpStack Gateway OS v4.2 test releases
Still the same issue of not supporting the LoRa Go PORT.
The concentratord configuration is not done properly.
I described the issue on the yocto bases OS here: Problem with Sandbox LoRaGo PORT shield conf
On this new version it’s the same situation: I’ve looked into the conf file in /var/etc/chirpstack etc… and the pin is still set to 0 after having chosen the Lora Port Go in the SX1301 conf part of the concentratord web interface. Obviously the gateway id is not updated.
The problem is that even by changing the PIN to 25 in the .toml file and rebooting, it doesn’t work in this case (I guess it can’t work if the gateway-id is not configured properly).
Would be great if this issue could be solved.
Thanks a lot for the good work.
