But the problem is that im not able to start the gateway bridge in my Multitech Gateway(outdoor ip 67). When I start the process it says that “Starting chirpstack-gateway-bridge” but when I stop it, it says the following “start-stop-daemon: failled to kill xxxx: No such process”.
May you please provide the exact model of Multitech gateway you are using, which firmware version you are running and the chirpstack gateway bridge that you are using. In addition to that, what’s the process that you have followed to install gateway bridge on your gateway.
What’s the log that the daemon is throwing? it’s just that message?
When the chirpstack-gateway-bridge is initialized it simply does not create the process. That is why it gives the error that says that the process does not exist when I try to stop the chirpstack-gateway-bridge.
I’ve been able to make it work, yes. But I dont know where does the socket error come from. Any idea?
I’m new to chirpstack and I’m a little lost. The problem is that it does not always show the error. Now it seems that I receive packages.
What socket error are you referring to?
Probably something that you can do at this stage is to read the official documentation to get familiar with all the components.
I am installing ChirpStack Server on my Multitech Base Station and I don’t know how to run the ChirpStack application’s web page. The IP address of my gateway is 192.168.0.100, then I put the port 8080 after the IP address but an error given.
Could you please show me how I can install ChirpStack application on your gateway? My mLinux version is 5.1.8.
