I have installed lora_gateway and the lora-packet-forwarder git repos from Lora-net in my raspberry pi 3B and made connections to my IC8808 board as indicated in the image below.
I compiled the lora_gateway and the lora-packet-forwarder repos successfully and produced the all their binaries.
My SPI for the Raspberry Pi is activated via raspi-config. I have confirmed that SPI is active by running cat /boot/config.txt | grep spi. My problem is that sometimes the packet forwarder choses to not start and give the following error. This issue persists for long when it starts. I receive the following error message continuously.
pi@raspberrypi:~/packet_forwarder/lora_pkt_fwd $ ./lora_pkt_fwd
*** Beacon Packet Forwarder for Lora Gateway ***
Version: 4.0.1
*** Lora concentrator HAL library version info ***
Version: 5.0.1;
INFO: Little endian host
INFO: found global configuration file global_conf.json, parsing it
INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
INFO: lorawan_public 1, clksrc 1
INFO: LBT is disabled
INFO: antenna_gain 0 dBi
INFO: Configuring TX LUT with 16 indexes
INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1, tx_notch_freq 129000
INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0, tx_notch_freq 0
INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: gateway MAC address is configured to B827EBFFFE243B19
INFO: server hostname or IP address is configured to "127.0.0.1"
INFO: upstream port is configured to "1700"
INFO: downstream port is configured to "1700"
INFO: downstream keep-alive interval is configured to 10 seconds
INFO: statistics display interval is configured to 30 seconds
INFO: upstream PUSH_DATA time-out is configured to 100 ms
INFO: packets received with a valid CRC will be forwarded
INFO: packets received with a CRC error will NOT be forwarded
INFO: packets received with no CRC will NOT be forwarded
ERROR: [main] failed to start the concentrator
I have made sure that the SPI connections and all pins are properly connected with the help of a multimeter. I tried two methods, namely by connecting the IC8808 board to the raspberry pi with jumber cables and also using intermediate PCB specially printed to make the above connections stated in the image. In both cases, I have received successful results. But at times, when this unit choses not to work, it just doesnt work for hours and sometimes a day or so. This unpredictable behavior is really frustrating⌠But it also means that my connections must be right. And I can assure that there is no lose connection from the Rpi end or from the IC8808 end. Below is a photo of both when they are connected using the intermediate board- A method that has worked but sometimes dosnt work. I have also tested with multiple raspberry pi3âs and multiple IC8808 boards. This issue is common to all setups.
Is this the place from which everyone gets their updated Packet forwarder and lora_gateway software? I am also worried that this is an incorrect repo as not many people seem to have this issue.
The git-hub repo I got my software from : https://github.com/Lora-net/lora_gateway
How can I solve this issue? Any advices are really appreciated.
observation : Once I keep on re-starting the packet-forwarder (sometimes over a half a day!) , it does start. When it did, I has run for weeks without trouble!
